| I tried to dress my CBN cup wheel with a diamond dresser and all I achieved was a nice shiny facet on the diamond. Cool, but not much use! ![]() How do I true the wheel to the arbor it is mounted on, and I lost the really sharp edge. Thanks ![]() Neil
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
![]() Cubic Born Nitride coated Aluminum similar to this but a much thinner bottom edge. About 3mm flat annulus. Thanks Dick.
| As far as i know, they are "maintenance free". When its wore, you get another one. These are made accurately, no need to true them when mounted. I shop eBay and got a bunch so I have more freedom to change out than most. Still, one stone lasts a LONG time. |
This is not maintenance. I must true it to the abor it is mounted on so that I can grind with micron resolution, re pointing solid carbide end mills, 25 at a time. Only takes 2 minutes, but if the wheel was truer it would be much quicker, and the points more precise.
| I can soon mount up a wheel to do the job. I have a nice motorized arbor in the form of a tool post grinder.
For me, if I take out the wheel from the flange or take the flange out of spindle , when I put it on, I must truing it. Usually I dress totally about 0.1 mm |
| neilw20 Dressing Sticks three different dressing sticks in a number of grits for you to choose. Aluminum oxide (white) Silicon Carbide (black) or Silicon Carbide (green). all of these are used for CBN wheels Plus the rotory method http://www.meister-abrasives-usa.com.../dressing_cups
__________________ Mactec54 |
#10
| Thanks mactec54 and thtalim (and other, too) for your replies. I just had to wait for the sun to shine in the right places. I will look through my abrasives box and probably find something suitable, know I have a better idea of the method(s) used. Neil.
#11
| to mactec54: Usually I use CBN FLAT WHEEL DRESSER to make sure the wheel is zero when check with dial indicator. After use, if the wheel is not sharp, I use stick, as long as the wheel still on the machine & the shape not change. (For me the wheel edge is important) See your attached file page 3: "The WINTER dressing device allows accurate dressing of diamond and CBN grinding wheels. During the dressing process the grinding wheel remains on the spindle which guarantees best concentricities." also: "If the grinding wheel acts too dull after dressing it needs to be sharpened with a wet WINTER stone No.1AW, No.2 or No.5." |
#12
| thtalim If you make a holder for the machine,so you can the mount the dressing stick,they work just as well as the rotory fixtures, were you put the tool to be sharpened this is were you mount the dressing stick & just move it across the face, or in some of the the small cutter grinders you can also mount the dressing stick were the diamond mounts the thing is to mount the dressing stick don't try & hold it by hand or you will mess your wheel up.
| Tags |
| cbn, diamond, dresser, grinding, sharpen |
| Best way to dress a flap wheel? | rkremser | Mass finishing equipment/media/stratigies | 4 | 04-24-2009 11:23 AM |
| MPG jog wheel | The Blight | TurboCNC | 6 | 06-12-2008 02:19 PM |
| What is holding this wheel in this pic? | sanddrag | Work Fixtures and Hold-Down Solutions | 10 | 05-03-2006 09:31 AM |
| RC car wheel files | Sanghera | Parts for Radio Control Models | 7 | 04-10-2006 09:10 AM |
| emc and powermate as a jog wheel ?? | harty | LinuxCNC (formerly EMC2) | 2 | 03-14-2006 08:49 PM |
