Old 11-25-2009, 04:17 PM
arizonavideo's Avatar
arizonavideo is on a distinguished road
Metal for cross slide
My old AI lathe has a worn out cross slide. It is a second op lathe so the carriage does not move it only has a cross slide and no threading function.
The infeed is still OK but the cross feed ways are gone, even with the gibe strip shortened and all the way tight I still have 1/4" of play.
I bought some 12mm rails and a nice small ballscrew to replace the cross feed but I will need to make a plate for the rails and a new tool mount. I will mount it to the old in feed slide.
I bought some hot roll steel and I have a IH mill to work the metal but I don't think the hot roll steel is the best choice of metal for the tool mount or even for the rails.
I don't know a lot about the different metals but is there a better choice of steel for the tool post mount that is not too hard or lots of money? I only found 4140 which I think is a little hard and expensive for this use.
The tool post mount will be 4" x 5" 3/4" and the rails will need to be mounted to a plate about 5" x 12" x 3/4".
Dave
Old 11-25-2009, 04:37 PM
ctate2000 is on a distinguished road
If you are going to use rails I would suggest cast iron. You can buy it from MSC or Mc Master Carr. It will be very stable and easy to work.
CT
Cross slide wiggles pzzamakr1980 Mini Lathe 5 01-13-2008 05:38 PM
Mounting dro scales to the cross slide wrenchcruncher General Metalwork Discussion 4 01-07-2008 06:27 PM
cross slide nantz Benchtop Machines 0 07-12-2006 06:09 PM
Cross Slide Lubrication sp00k1e General Metal Working Machines 0 02-12-2004 05:05 PM
Cross Slide Vise Recommendation edge General Metal Working Machines 4 07-24-2003 02:15 AM
