I am looking for a good general purpose coolant for flood cooling in a home based workshop. This is not going to be used on a daily basis so it will either have to be stored for long periods or disposed of after each use. Machining will be mostly aluminum parts which will most likely be anodized, so staining will be a concern. There will also be occasional jobs involving common steels, plastics and other non-ferrous metals. The flood cooling system will be pretty basic using a rubbermaid type container for storage, a filtration system, pump and aerator. So I guess the synopsis of my criteria are as follows: 1. Inexpensive (good value) 2. Non-toxic or biodegradeable (need to be able to dump this down the drain or easily dispose of it) 3. must be stable when stored 4. must be good on a variety of materials, primarily aluminum alloys. What can you guys recommend? |
| For infrequent use and having to dispose of "hazardous" waste (due to infrequent use) I would suggest using a Mister system instead.
| Hi RP designs What you want I can supply you with the cutting fluid is 100% synthetic, Biodegradable,Non-toxic,Fireproof, It is called GreenCut It is not cheap but is the best cutting fluid that is out there, It will never go bad does not need aeration & smells good 1 liter makes 5 gallons of cutting fluid you can PM me for more information
__________________ Mactec54 |
| EnviroServe Chemicals, Inc. has been in the metalworking fluid and coolant business for 15 years. We have concentrated in the southeast US for the bulk of that time, but since our business has grown significantaly in the last 18 months, we now have service in the northeast and mid west. Since we manufacturer our own products, you aren't paying for the distributor's mark up. All of our coolants are as environmentally friendly as possible, they are stable in solutions as low as 0.5%, and they work great! Shoot me an email if you would like and give me some specifics. I do give free trial samples to match a determination run. Look forward to hearing from you. Jonathan Ballard EnviroServe Chemcials, Inc. jsballard@enviroserveinc.com |
| I am planning to use mobilemet 404 oil for infrequent use. No issue with rust from water base/diluted fluids. Is supposed to have good pot life, no odor, low cost, no staining for aluminum & brass. Yes it is messier, but with a parts washer nearby should be okay. Or did I read the catalog page wrong? |
| bigspike GreenCut is what you need 100% Enviro-safe Machining the only way to go & 100% Biodegradable All oil base cutting oils will go bad, GreenCut will never go bad no matter what the conditions you put it under it is 100% Synthetic as well & you never need to change it, I can supply this product.
| I use this stuff in a manual lathe. It's been in there over a year now, still looks and smells fresh even though it only gets used a few minutes per month. http://www.tricocorp.com/products/product.aspx?c=5&p=27 I got 2 liters of the concentrate (enough to last me a lifetime, it seems) from a seller on Ebay for about $12 shipped. |
| Flood coolant option | truline | Haas Mills | 14 | 05-18-2011 06:00 PM |
| Flood coolant evaporation | rezcar | General Metalwork Discussion | 4 | 09-26-2009 09:03 AM |
| Flood Coolant - how to maintain? | Rich05 | General Metal Working Machines | 4 | 06-12-2008 07:06 PM |
| What is everyone using for Flood Coolant Filters? | SpeedsCustom | Benchtop Machines | 15 | 04-14-2008 11:37 PM |
| question about flood coolant | nicad | General Metalwork Discussion | 6 | 10-24-2005 10:03 PM |
