Old 11-19-2009, 07:30 PM
StefanV is on a distinguished road
Machining info
So I build a small cnc router table doing some engraving and making pcbs. I would like to build a stronger machine. I figure I can cut some parts for the new machine in aluminum or even steel on the small router if I go slow. I now use a trim router as a spindle.
Is there any information out there, websites, books, that can teach me some machining basics? I need to figure feed rates, cutting depth, speeds, for different materials, using different bits. Looking on Amazon I can't make out what's useful in my case.
Any advice is appreciated.
Stefan V
Old 11-23-2009, 08:21 PM
cncprofessor is on a distinguished road
Smile Speeds & Feeds
Try this:
http://maelabs.ucsd.edu/mae_ms/feeds_speeds.html
http://www.niagaracutter.com/techinf...eed/index.html
http://www.stanford.edu/group/prl/do...pdf/mlspfd.pdf
http://www.efunda.com/processes/mach...ormation_2.cfm
http://www.americanmachinist.com/Cal...eedsFeeds.aspx
Have fun!
Looking for info extsuba Want To Buy...Need help! 0 10-04-2009 01:16 PM
Looking for info Chuck33 Cimatron 0 03-22-2009 11:05 AM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
need info on 4 axis machining greggv General Metal Working Machines 7 02-18-2005 12:08 AM
