| An anodizing kit is what you are looking for. Have you tried searching here on CNCzone it has been discussed many times. You will probably also find information if you use Googel and search for 'home based anodizing' or something similar.
| While anodizing is far more common, I will take the poster at his word that he wants a "Black Oxide" treatment for aluminum. These are also available. For example, via this product: http://www.epi.com/pages/aluminum-blackening Caswell has a lot of metal treatments for small batches, though I didn't see any black oxide for aluminum. For really small batches and no muss/no fuss, this product from Brownell's works reasonably well: http://www.brownells.com/.aspx/pid=4...ALUMINUM_BLACK None of these alternatives will give as nice a finish as anodizing, however. Cheers, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
| Which finish is more tougher, anodized or black oxide for aluminum? I will be making some clamps for my mill and will need some form of rust protection. I was told that black oxide is tougher/stronger/more-durable than anodized aluminum. Is that correct? Thanks, |
| I had a look at the links in the other post and they seem to be not much more than paint; this is a comment in one of them It is not as hard as a black anodized finish. The hardness of the finish can be enhanced by top coating with a clear lacquer.... Really you do not need to worry about doing anything to protect your clamps.
Yes but the cost difference is most likely not much greater with the ano vs black oxide. I don't know to much about the black oxide but I am sure the prices aren't to much less than what I could anodize for. I am not sure. I am just saying stick with anodizing! |
| I'm with Geof. Those products are alternatives to anodizing to achieve mostly a cosmetic effect. Anodizing will give you the best result. The cold bluing formulas for steel are more useful, but you're doing aluminum. If you want something quick, dirty, and cosmetic just so your clamps have a finish, consider the other products. But if you want to do it "right", anodizing is the way to go. Cheers, BW
#11
| I did some research and there is a Hard Anodizing DIY process at http://www.diyanodizing.com/diy_hard_anodizing_kit.html. This would give the aluminum excellent hardness and corrosion resistance. This is similar to Hard Anodized pots and pans used for cooking. |
#12
I seen that website before and it looks like some chinese knock off website.. They are based in china. They do have low temp black oxide.. I mean you get what you get it isn't true black oxide coating. |
| How to tell the difference in Black ABS VS Black Delrin? | conceptmachinin | General Material Machining Solutions | 5 | 10-17-2011 09:43 AM |
| More monitor black out | Kool Parts | Haas Mills | 2 | 10-28-2008 09:22 AM |
| WHO Does Black PVD? | mabmojo | Metal Finishing and Plating | 0 | 09-25-2008 09:56 AM |
| PSU surge protection - Metal Oxide Varistors | UKRobotics | General Electronics Discussion | 4 | 07-16-2007 12:30 PM |
| Why are my aluminum parts turning black? | widgitmaster | General Metalwork Discussion | 9 | 09-27-2006 10:10 AM |
