Old 11-11-2009, 05:47 PM
Rich05 is on a distinguished road
Carbide tools for Aluminum?
My mill does not run too fast 3,500 rpm tops. Question is should I be buying carbide.
Old 11-11-2009, 06:16 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
it depends upon what type of work your doing , carbides have come down considerably in price so they are much more affordable and have a number of benefits over hss , tool deflection is less with a carbide and wear is generally better as well ,cut depth , tool engagement etc , but carbides not as forgiving as hss if the table has a bit of slop to it . I think it's good to have both , many may say differently but to each his own, i think most of us tend to know what will be best for our own applications . i have a wide array of carbides that i can pull off the shelf when i need one and it's something that i do whenever i need one but right now my small mill in my workshop has a 1/2" 3 flt hss in the spindle , I like to use hss as a general low cost tool that i have no concerns with abusing
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 11-11-2009, 09:04 PM
thanks for reply, good info.
Old 11-11-2009, 10:40 PM
MadMax is on a distinguished road
I'm not sure, but there may be differences in adhesion between carbide and HSS. One might not pick up as much built up edge than the other. Personally I like carbide. If I ding an edge in a tool changeover, I swap or turn an insert and don't even have to retouch or grind. If I have a coolant failure do to a plugged coolant port, I usually find that the carbide trucks along decently well, but you can overheat HSS more easily.
Old 11-11-2009, 10:42 PM
Hayworthmilling is on a distinguished road
What kind of mill and how much hp?
On most manual machines 2hp and under, HSS 4-flute endmills work fine. No need for carbide, and no need for 2-3 flute "aluminum geometry" endmills either since you can't really clog the flutes without more power. Just use plenty of WD40.
Old 11-14-2009, 12:47 AM
CaseyCAM's Avatar
CaseyCAM is on a distinguished road
Well running 600 rpm on steel is not unheard of... 3000+ rpm is fine for cutting aluminum with carbide.
Also, I use carbide on aluminum without a hitch. You'd think that because its so brittle it'll snap but i've had great luck with it. A good suggestion would be to use 2flute end mills. 4-flute will be more opt to "gum" up with aluminum.
Also, if you don't mind spending a little more cash get 7000 series aluminum (aircraft grade) its got a "crisp" cut chip, not as gummy as perhaps 6061.
Old 11-14-2009, 01:20 AM
Billet Sean's Avatar
Billet Sean is on a distinguished road
To add to that, Copper & Brass has a 6262 alloy that is awesome to machine and is priced between 6061 and 7075.
Sean
Old 11-16-2009, 08:45 AM
kling8 is on a distinguished road
I would use carbide without question. They have carbide tools for cutting aluminum, I use these daily. I would recommend a 3 flute aluminum carbide end mill on tool dia. .25 and larger.
Old 11-16-2009, 09:17 AM
If you choose to use carbide get the micrograin high helix type with the polished finish for aluminum. They do give a nicer finish and they do clog less easily than regular carbides. Don't worry about getting any coated carbides.
Always use some form of lubricant or coolant. I know a lot of people suggest WD40 and it does work but not as well as a proper water mixed coolant which is easier to clean up. Just get a plastic spray bottle and fill it with the coolant mix. Alternatively use the coolant straight and just brush it on along the line of the cut; before turning on the machine!!
Reshrpening Solid Carbide Tools brainlessme Toolgrinding & Toolgrinding Machines 3 05-28-2012 03:09 PM
dijet carbide tools avaitsis Metal Working Tooling 2 03-02-2009 12:13 PM
cheap carbide tools eggo Australia, New Zealand Club house 1 08-04-2008 12:27 AM
Carbide Cutting Tools John Pepper Product Announcements & Manufacturer News 1 12-07-2007 02:47 PM
Where can I buy metric carbide tools? tahustvedt General Metalwork Discussion 5 10-03-2007 01:39 PM
