Old 03-21-2005, 10:57 PM
duraflap is on a distinguished road
Help!! Machining Alum with a cnc router.
I need help with machining alum with my cnc router.
Can you help me out?
Thanks in advance
Old 03-21-2005, 11:40 PM
psychomill is on a distinguished road
What kind of help do you need? Can you be a little more specific? What problems are you having?
Old 03-22-2005, 10:54 AM
Hi there
I'm using a .250 spiral up bit with a spindle speed of 10K, the slowest speed on my Porta Cable 3 hp router.Cutting dry at about 40 ipm feed speed and multiple passes of .05 using kerosene brushed onto the work surface for a lube. This all works great on T6 alum but not on softer material. I've played with the feed speed and cutting depth with no improvement so far.
The problem is that the soft alum sticks to the bit and if I continue, will fuzz up the cut and pile the material up the sidewall instead of creating chips.
I realize the spindle speed and dry cutting are not prefered, do you have any options for me?
Thank you for your help
Dennis
Old 03-22-2005, 12:18 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
A 4 flute cutter should run closer to 80 IPM at that RPM (2 flute would be about right), but your biggest problem is coolant/lube. You really need to get a heavy dose of it on there. You could also try a TIALN coated cutter, might help keep the chips from welding.
www.integratedmechanical.ca
Old 03-22-2005, 02:22 PM
Coolant!!
Kerosene is not enough lubricity especially at your minimum RPM with that size cutter. May want to try a slower helix tool as well since you can't get slower on the rpm. The helix angle may pull the material too fast for your set up. Are you cutting an extrusion?
Old 03-24-2005, 09:15 PM
Tomorrow I get to play with this problem again. I'll try these suggestinons and hopefully have a home run. Thanks to you all, I appreciate the helpful suggestions.
Dennis
Old 03-24-2005, 09:18 PM
Just a different thought. Does anyone know of an electronic speed reducer that will work on the big Porta Cable router? Anyone know how to slow the router down?
Old 03-24-2005, 10:52 PM
JRoque is on a distinguished road
Hello. I've had problems cutting aluminum with 4 flute endmills. TiAlN, 2 flutes @ 6000 RPM does the trick for me.
As for the Porter Cable speed control, there's nothing you can add externally to slow it down. If you really want to do that, and void the warranty in the process, you can remove the speed control on-board the router and wire it directly so you can use an external speed controller for universal motors. A few things to keep in mind: common speed controllers might exceed the power rating of the motor, at lower speeds you won't have full HP output, lower speeds will not operate the fan at the required rate and overheat the motor.
I also own a PC router which I used for about 2 months before giving up and making my own spindle with a DC motor. Life's good now or at least better than before.
JR
Old 03-24-2005, 11:04 PM
Nono's Avatar
Nono is on a distinguished road
Anytime that I have cut aluminum there has been a high stream of coolant. Sounds like high RPMs means faster feed rate and less depth of cut but definatly more coolant. Sound fun whatever you are cutting
Old 03-28-2005, 11:11 PM
Well, The T-6 x still cuts just fine and the 4043 still gums up the bit and makes a mess out of the work piece. So... JRogue, how did you go about building your spindle from a DC motor? Would you care to share your ingenuity with this dummy? I think it is a great idea!!
Dennis@duraflap.com
  #11   Ban this user!
Old 03-28-2005, 11:13 PM
By the way, thanks to all of you for your input, it is all helpful...many thanks
Dennis
  #12   Ban this user!
Old 03-29-2005, 06:50 AM
With a little help from my friends. Actually, a lot of help. Until I can get all the details under my machine log, check this thread for the entire discussion.
Regards,
JR
Building a CNC router HomeCNC CNC Wood Router Project Log 230 10-18-2009 06:56 AM
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 10:12 PM
2nd Generation CNC Router Design 32.5” X 14” X 6” gregmary DIY-CNC Router Table Machines 9 03-24-2005 04:46 PM
buscht's cnc router buscht DIY-CNC Router Table Machines 25 04-13-2004 11:43 AM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 10:18 AM
