Old 11-08-2009, 06:12 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
what size drill for tap?
hello!
On my x3, i swapped the gears, but one of the pulleys was not supported as you can see here
On the left, is the motor shaft. The gear popped up when i was machining a part and destroyed the belt, so i need to hold the gear down.
I was going to drill a hole in the shaft and tap it to 10-32 so i can use a little 10-32 screw that would be perfect i have laying around.
I cannot find what is the proper size drill bit however, that i need to use to drill a proper hole so i can tap it proper. i only have one shot to do this correctly.
Thanks a million
Old 11-08-2009, 06:19 PM
#21 drill is for 10-32 and I think 5/32" is very close. Depending on how deep the hole is and how much thread engagement is possible you can go to 11/32"; this is easier to tap but the thread depth is reduced to about 60% of full form whereas #21 gives you about 75%.
Need Help!- formula for drill size cam53 General Metalwork Discussion 12 11-30-2008 12:36 PM
Tap & Drill Size kiemkhach General Metal Working Machines 2 03-12-2008 11:54 AM
what size steppers for a mill drill? CNC Darren Benchtop Machines 1 10-04-2005 11:36 AM
Size motors for Mill Drill Runner4404spd Benchtop Machines 4 06-19-2005 01:09 AM
What size of drill bit can be used for 1/2-10 acme tap? starCNC DIY-CNC Router Table Machines 11 04-29-2004 05:36 PM
