I am looking for a way to countersink (90 degree) the underside (bottom side) of a 1/2" diameter hole in 6060 1" thick aluminum. I already have a countersink bit to cut the top side of a hole so that I do not have to worry about deburring the hole, but need to do the same to the bottom of the hole all without moving the stock that is mounted to my CNC mill table. My question is, is there a special countersink to do this? Thanks, |
| Use a 45 degree dovetail cutter, they are available in 1/2" diameter with a 3/8" shank. All you have to do is grind the head down a few thou to pass through your 1/2" hole and you still have enough over the shank diameter to do a 20 thou chamfer.
| Geof beat me to the answer... If your tool changer is full or you want to save a toolchange, I have used double angle cutters in the past with success. Mine were from Harvey Tool. |
| Problem- countersink possible in alphacam? | oakleigh | General CAM Discussion | 5 | 08-21-2009 04:59 PM |
| Countersink Hole | samseksek | Fagor Automation | 3 | 06-09-2009 09:22 AM |
| 87 degree countersink | Rainbird | General Metalwork Discussion | 2 | 09-10-2007 01:07 PM |
| countersink 304 stainless | jprobst | Haas Mills | 18 | 06-16-2007 03:20 PM |
| pcb underside coatings - whats a diy version ? | bobJandal | General Electronics Discussion | 4 | 10-09-2006 01:11 AM |
