hi crafters and philomaths, I need some 48 DP spur gears, ca 90 tooths, Pinions I already have - PA 20°, Very hard to get these spurs from aluminium (or stypidly expensive), thats because tried to find Gear Cutter and DIY , the only cutter I found and bought is No2, 48DP, PA 14 1/2°, I will use Aluminium for Spurs, pinion is plastic. Question: Will I have big problem when 90 tooth spur has PA 14 1/2° when 20 tooth pinion has PA 20° ??? Cheers, Herbert |
| Herbert, A 20 deg.PA should not be run against a 14 1/2 deg. PA. That may work for a short time on gears made of soft material, but will wear rapidly. Involute gears "roll" against each other. Different pressure angles running against each other will interfere and "rub" causing wear. A 20 deg PA gear tooth is thicker than a 14 1/2 deg. PA tooth and will not fit well in the tooth space of the 14 1/2 deg. gear. Dick Z
__________________ DZASTR |
| Hello Herbert, Have you looked at the gear selection of Maedler.de? The metric Module gears are PA 20°. They don't have aluminium, but the do have plastic 90 tooth gears.
__________________ Regards, Mark www.wrathall.com |
| Yeah guys, many thanks for reply. Pinions I have are very specifics, made especially to fit with ´something´, thats because I need the spur what fits exact. Plastic spurs I did think about ... but rather no, it will louse up my design. Spurs I need ... lets speak about 50 ... 100 pieces, means that when to buy per 20£ then I have to gnaw moss instead of to get some profit after hard work ![]() Also sent few emails to gearcutter companies advertises custom gears - no reply, Why they making those differend angles at all, why not just one ![]() Seems the only way is to find 48DP No2 20 degree gear cutter, Spent already two days and cant find ... regards, herbert |
| Yeah, some humdinger machinist can do what ever, not me with my modest knowledge about. Thanks to ´Finegrain´ from PM forum at last I found needed cutter for $ 56.27 and already ordered, 48 D/P #2 E188 20º INV. HSS GEARCUTTER TTC PROD Product: 10-289-482 Im not a grudging guy - perhaps someone else will need this address http://www.travers.com Cheers, Herbert |
| Need Help!- Gear Cutting | Martin Long | BobCad-Cam | 13 | 08-25-2008 09:08 PM |
| Gear cutting on the X3 CNC | John S. | Benchtop Machines | 6 | 12-07-2007 07:26 PM |
| Gear cutting | watchman | General Metalwork Discussion | 10 | 02-15-2007 06:12 AM |
| Gear Cutting | chuckknigh | DIY-CNC Router Table Machines | 12 | 06-01-2004 06:30 PM |
| Gear cutting | danswen | General Metalwork Discussion | 1 | 11-04-2003 11:27 AM |
