Old 10-24-2009, 08:21 AM
accramachine is on a distinguished road
Help with Fanuc Series 0-M
Hi all I just recieved a supermax vertical mill with Fanuc 0-i control. I didn't get an opperating manual with this machine. I am familiar with Fanuc 6T but these two controls are slightly different. With the 0-i how do you get to the comand screen after you turn the selector to MDI ? Also how do you go about removing old programs from the control ? I would also like to find a manual for this control if anybody knows where I may find one? Thank you in advance for any help on this subject.
regards, John S. Wracher
Sorry guy's, I listed the wrong control number. It is a "Fanuc Series 0-M" the question remains the same though, any help would be great. Thanks again.
John
Last edited by accramachine; 10-24-2009 at 03:40 PM. Reason: Listed the wrong control number
Old 10-24-2009, 02:13 PM
alexfanuc is on a distinguished road
Oi Control
The comand screen is the Program screen. There you can "insert" the comand and then the EOB (end of block After that you can cycle start. It is not like the 6 control.
Regards
Alexfanuc
Old 10-24-2009, 03:09 PM
leggazoid is on a distinguished road
In edit mode type the program # you want to delete followed by the delete button.
O0001 delete
to delete all programs...
O-9999 delete
to delete range of programs...
O1,O3 delete
Old 10-24-2009, 03:26 PM
Al_The_Man's Avatar
I have a power mate i that should be close if you care to P.M. me and email add.
Old 10-24-2009, 06:13 PM
this manual may be close...
http://www.stankomach.com/catalog/fa...64124EN_01.pdf
Old 10-25-2009, 05:50 PM
Yes Thank you, I downloaded it and it appears to be useful. Thanks again to all whom responded.
Accra Machine Shop, Inc.
FANUC O CONTROL gabedrummin Fanuc 12 06-07-2009 02:32 AM
G13 on Fanuc 0i control davisboys Fanuc 4 09-01-2008 08:25 AM
FANUC OM CONTROL gabedrummin Fanuc 0 08-28-2008 04:41 PM
Fanuc T6 Control adamant G-Code Programing 5 12-19-2007 11:09 AM
INT 412 with Fanuc control Jurek Bridgeport and Hardinge Mills 0 12-16-2007 04:34 PM
