Old 03-17-2005, 08:23 PM
machinist360's Avatar
machinist360 is on a distinguished road
Mazak Mazatrol T1 Parts
Does anyone have a good mazatrol parts supplier?
Old 03-17-2005, 08:28 PM
Al_The_Man's Avatar
What are you looking for, I usually buy from Mitsubishi Chicago.
Al
Old 03-18-2005, 09:04 PM
I need a monitor, or a monitor rebuild for starters. I also need a servo amplifier. Have you ever found anyone with a supply of used parts?
Old 03-19-2005, 11:14 AM
Al_The_Man's Avatar
Is the screen dead, or just very dim? As I have just replaced the crt in one Mazak T1 with a crt from an old 12"? monochrome monitor, if this is the case, what I did was seek out somewhere that has old PC monochrome monitors (they are becoming rare, but $5 or $10 ea.) and find a tube with the same phyisical diminsions also the same scan angle, thats the angle of the crt from the screen to the neck. If you feel you don't want to handle the swop yourself, any TV or PC repair shop would do it. Its probabally over $1,000 for a new one, if you can get them.
Al
Old 03-21-2005, 04:57 PM
For a little while when you powered it up it would be small and scrambled. You had to cycle the power a couple of times and it would be fine. Well, of course after a few months of this it quit righting itself and now it stays that way. We have other T1 machines, and I swapped it out and it is definitly in the monitor. Then I had to rob a servo amplifier to fix one of the other machines. I may just part this thing out, or sell it all together. It's a quickturn, about a 83 model. I don't know do you have any ideas?
Old 09-17-2006, 10:13 PM
Tony Alt is on a distinguished road
Hello
My high voltage coil burned out on my QT-15 lathe monitor.
I want to replace it with old monitor from a computer.
Do you have the pin out from the Mazak monitor?
Will an LCD new monitor work?
Bye
Tony
Old 09-17-2006, 10:19 PM
Al_The_Man's Avatar
You need a TTL monitor (Old technology) I will try and look the pin out up tomorrow.
Old 09-21-2006, 06:48 PM
Hello
Thanks for the help
I think there is a 6 pin white connector
Bye
Tony
Old 09-21-2006, 07:26 PM
Al_The_Man's Avatar
What control is it? The pinout I have is for the older monitors, that go to the 20 pin Honda connectors.
Is it monochrome or colour?
Old 09-25-2006, 07:42 PM
Hi Al
The control is a T32B
The connector is a rect. 15 pin. Only 10 pins have wires on them.
It has an amber screen.
Bye
Tony
  #11   Ban this user!
Old 10-18-2006, 06:42 PM
Hi Al
Bye
Tony
  #12   Ban this user!
Old 10-20-2006, 04:30 AM
rhino's Avatar
rhino is on a distinguished road
the last couple of places i worked for nearly payed for the people to take the parts away.
On the other hand, You have different fingers.
Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1' Haaatschi Machine Problems, Solutions , Wireless DNC, serial port 20 08-22-2010 12:55 AM
Cnc Parts Parts And More Parts berin CNCzone Club House 2 07-27-2010 02:21 PM
RFQ two Aluminum parts, cheap no rush mike_r Employment Opportunity 0 04-28-2005 10:14 PM
Mazak H15 with Mazatrol M2 Steve_rb Machine Problems, Solutions , Wireless DNC, serial port 1 03-19-2004 06:27 AM
