Old 10-21-2009, 12:54 PM
ignisuti is on a distinguished road
Need name of X-Shaped Metal Bars
I want to know the name of the X-Shaped Metal Bars I see in a lot of robots as well as general prototype use.
I believe it is an aluminum material, but can’t seem to find the name of it searching through Google.
I was considering using that material as the frame of a CNC machine that I'd like to build. Anyone have any other suggestions? I'm guessing rigidity and low vibration is the primary goal for the frame.
Old 10-21-2009, 01:22 PM
george4657 is on a distinguished road
enter 8020 aluminum on google or Ebay and you will find a lot of examples
George
Old 10-21-2009, 02:48 PM
That's it. Thanks!!
Anyone recommend a different material for a CNC frame?
Old 10-22-2009, 02:25 AM
Cartierusm is on a distinguished road
Depends on what kind of CNC you're making? I made a very sturdy router out of 8020, but if you're cutting metal then no.
Old 10-22-2009, 09:17 AM
Right now, I'm thinking of mostly using it for PCB milling and possibly some woodworking, but it'd be nice to have the option to machine some metal if needed. What would you recommend as a frame for this purpose?
Old 10-22-2009, 12:21 PM
If you're going to be doing full blown metal get a mill. But if you just want to do light aluminum cutting then 8020 is perfect.
Funny shaped Cam lobe stevehuckss396 I.C. Engines 17 02-14-2010 05:02 PM
Help with egg shaped circles Trucks DIY-CNC Router Table Machines 14 09-28-2009 06:37 PM
Shaped Tools patycoop SolidCam 3 02-10-2008 03:58 AM
Perfect shaped circles needed - Please help organetic DIY-CNC Router Table Machines 1 05-03-2007 07:32 AM
Bending a U shaped MBG Bending, Forging,Extrusion... 10 06-15-2006 11:27 AM
