Results 1 to 5 of 5
Thread: Need help finding these inserts
    Wanna be
    Mar 2004
    Need help finding the inserts for this thing. You can see that there are a couple of them that are broke (Newbie Mistakes) They are 1/2" Square and about 1 1/2" Long. They appear to have a carbide tip on them. Would prefer to find some already ground as my grinder is worthless. If not, I can always use this as an excuse to the wife to need a new grinder.
    By the way, what is this proper name for this thing?
    Dan
    Attached Thumbnails Attached Thumbnails Need help finding these inserts-im000141.jpg
    Check out what I am working on at www.routerbitz.com!
    wms
    wms is offline
    Moderator wms's Avatar
    Mar 2003
    Hack,
    That is a "Shell" mill..those look like lathe tool bits..any supply house..or Enco, MSC, KB, Travers, or the like...you can get them with different lead angles...
    Feb 2005
    What is that called, ancient. We have a couple of those kicking around the shop, I don't think they are exactly the same, but as far as I know they have never been used as long as I've been there, e'mail me if your interested. I would suggest going to something a little more "modern". There are so many better indexable cutters out there, its really hard to grasp what geomety and shape can do until you see it for yourself.
    S.N.A.F.U. miljnor's Avatar
    Jan 2005
    I have one of those (maybe its 4) but owell they were inherited with my bench top mill and I just replace the grindable carbide with the mini indexable carbide tipped lathe tooling you can buy from almost anywhere
    I think even Fubar frieght has them, but not sure.
    Michael T.
    Jan 2005
    Hi you will need a green carbide grinding wheel or diamond wheel to be able to grind
    it properly Yes lathe cutting tools will work fine you will have to cut them shorter
    as the 1/2" square will be about 3" long, You have 4 cutters in that holder, Try it
    with 1 it will then be like a flycutter, and grind some rake on the top of the cutter.
    You can also use HSS cutters which are easer to grind than the carbide tip cutter
    1. need help finding specs on motor
      By CNC Darren in forum Stepper Motors and Drives
      Last Post: 06-05-2012, 07:59 PM
    2. Finding The Right Router
      By Crushmonkey in forum Commercial CNC Wood Routers
      Last Post: 06-19-2006, 02:17 AM
    3. Need help finding the right computer. Please!
      By whipsnade in forum Computers and Networking
      Last Post: 06-14-2006, 06:25 PM
    4. Need help in finding
      By brtlatjgt in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 06-03-2005, 12:31 PM
    5. Ceramic Inserts
      By Turbine in forum CNCzone Club House
      Last Post: 09-24-2003, 10:23 PM
