Results 1 to 7 of 7
Thread: What is the best grade Stainless Steel for eating utensils???
    Aug 2007
    What is the best grade Stainless Steel for eating utensils??? Does anyone know which is the safest for making spoons and forks with??? Thanks.
    Apr 2005
    bih
    I think most of it is 1810 (AISI 304)
    Feb 2006
    As I understand it, Only the 300 series grade is truely corrosion resistant ! that would be any 3xx grade.
    Don
    IH v-3 early model owner
    Apr 2008
    If you put a magnet to the 304 alloy you will notice that it sticks to it because there is a small amount of Fe. in it and it will corrode,though slowly.
    316 would be a much better alloy and is not much more expensive than 304.
    The kitchen sink is made of 316 usually and is very durable.
    Aug 2008
    Denmark
    Quote Originally Posted by Cruiser View Post
    problem is 300 cannot be hardened, maybe not a big problem for
    spoons, forks and a simple knifes, where being able to put it in the
    dish washer is more important
    For knifes that need to be sharp I believe something like 420 or better 440 is used.
    -L
    Jul 2006
    Mar 2005
    Toronto, Canada
    Quote Originally Posted by Nastyzen View Post
    does this stuff just get pulled out of thin air? all stainless steels have lots of Fe, like 50% or more, more Fe than anything else.
    if a stainless steel has a 'ferritic' structure its magnetic - 400 series. The most common stainless steels though are 'austenitic' which isn't magnetic - 300 series, its the way the Fe and nickle interact in the austenitics that make them non magnetic...but's its still mostly iron.
    A lot of cutlery is made from ferritic that has carbon added (is then called martensitic) because it can be hardened, ie a 400 series that's harden-able
    anyway, I'm not a stainless expert, but they all have tons of Fe
    1. Stainless Steel
      By jdclark in forum Shopmaster/Shoptask
      Last Post: 02-24-2009, 11:08 PM
    2. turning 430F grade stainless steel
      By callganesh in forum General Metalwork Discussion
      Last Post: 11-03-2008, 04:25 PM
    3. Stainless steel
      By larry53 in forum General Metalwork Discussion
      Last Post: 04-23-2007, 12:32 AM
    4. Steel or Stainless
      By tool_man in forum Casting Metals
      Last Post: 10-29-2006, 06:46 AM
    5. Is stainless steel
      By CNCadmin in forum Hard and High Speed Machining
      Last Post: 10-17-2003, 09:19 AM
