Old 10-15-2009, 03:41 PM
SSI SSI is offline
SSI is on a distinguished road
Tap feed and speed help!!!
I am new to this site....I am tapping through aluminum. I am tapping a 2.5mm hole using an M3x.5mm tap. I have the speed at 200 and the feed at 6.2. What would the correct speed and feed be? Thanks
Old 10-15-2009, 04:43 PM
underthetire is on a distinguished road
speed and feed
6K rpm on a brother or robodrill. 1 rpm on a bridgeport. Anywhere in between with other machines.
Point of all this-more details.
Old 10-15-2009, 06:42 PM
SSI SSI is offline
im using a daewoo 3016L
Old 10-16-2009, 07:58 AM
Andre' B is on a distinguished road
You can spin it faster, at some point your control may not be able to keep the spindle and Z axis in sync and you will start getting bad threads. The only way to find out is to try it.
If you feed a tap at anything other the lead of the thread and you will not get the threads you are expecting.
Old 10-17-2009, 05:27 PM
muddobber76 is on a distinguished road
Let's start by giving us some more data:
Is this machine a lathe or mill or mill/turn?
Do you have ridgid tap function?
Is it a thru-hole or blind hole?
What type of tap are you using; carbide,HSS,spiral,bott,etc?
How many holes per part?
How many parts total?
Tapping is one of those processes that you must weigh all variables in order to achieve desirable results. Proper set-up is absolutely critical if you are tapping a production run.
Old 10-18-2009, 03:48 PM
timlkallam is on a distinguished road
At 200 rpm your feed would be 3.937 ipm
Tim
How to set feed speed IMK1230 G-Code Programing 3 07-01-2009 06:41 PM
feed & speed mdf ? frankgranit Français CNCzone 1 11-14-2008 02:18 PM
Speed & Feed kal_pesh Mastercam 4 02-23-2008 01:19 PM
Speed And Feed superrotary General Metal Working Machines 0 09-27-2007 10:23 PM
speed and feed KBW General CAM Discussion 2 02-20-2004 09:18 PM
