Old 10-12-2009, 06:06 AM
fitzpatrick2362 is on a distinguished road
B axis rotation
My mind has gone blank!!
Say I want to drill a hole at 45 deg.
Assume that the component is set up at machine-x0 y0 and the hole being drilled is lined up along y0.
B0 is the front of the part and the hole being drilled is at B45.
When using a horizontal machining centre, the tombstone pivots around the centre of the tombstone.
If you then have a fixture on the tombstone and then the component then the co-ordinate of the hole could be at say Z300.
This means that when you rotate around to B45 the component is not rotating around the centre.
Using trig calculations how do you arrive at the new x and z co-ordinates.
There is an excel based calc on the internet but you have to pay for it called 'fixture offset calculator'
If anyone has a freebie thaen that would be great.
Hope I have explained this.
B axis rotation formula. fitzpatrick2362 General Metal Working Machines 2 11-20-2009 12:51 PM
A axis continues rotation ? thirty78 G-Code Programing 4 12-13-2006 01:47 PM
Rotation control help on A axis Art Ransom DIY-CNC Router Table Machines 27 09-23-2006 07:04 AM
X axis to A rotation quemast G-Code Programing 6 06-17-2006 08:36 PM
Converting X axis to A rotation quemast GibbsCAM 2 06-09-2006 10:17 AM
