Old 10-11-2009, 07:15 PM
sunworksco's Avatar
sunworksco is on a distinguished road
Threading PVC Pipe,Inside Diameter
I am searching for information how to thread the inside diameter of 4" schedule 80 pvc pipe which has a wall thickness of .337".The female thread needs to be a coarse and straight.I am also needing a threaded male plug with an o-ring for sealing the pipe.This project will be used for a scuba water tight container.
Thanks,
John
EMC2 variable pitch / variable diameter threading. samco General Metalwork Discussion 0 03-09-2008 01:40 PM
Proper diameter drill rod or bar stock for threading? quick toy Mini Lathe 6 12-02-2007 06:34 PM
Pipe tap threading camtd Surfcam 5 03-15-2007 04:58 PM
Looking for a source or 1/2" diameter 8" length boring profiling and threading bars Green0 CNC Tooling 1 01-04-2007 09:46 PM
Diameter of inside cut, too small SVM General CAM Discussion 16 06-19-2006 09:17 AM
