Old 10-07-2009, 10:47 AM
Pontiff51 is on a distinguished road
center drilling
Hi all. I'm center drilling into 17-4 SS tubing, carbide tools chip and our regular KEO tooling will not last too long. Any other center drill material that anyone knows about?
Thanks in advance.
Old 10-07-2009, 01:16 PM
Brepins is on a distinguished road
hss s1200 z-.035 f6.
Old 10-07-2009, 01:45 PM
beege's Avatar
beege is on a distinguished road
Guhring makes some nice metric spot drills, cobalt. In any case, cobalt would be the way in 17-4. I never use center drills. Way too much time to get to a decent depth, and it was designed for parts that get ground between centers.
Old 10-08-2009, 09:56 AM
Delw is on a distinguished road
I've used KEO center drills for over 20 years, they work in just about anything even inconel 718 and in my Opinion are the best. you also mentioned Carbide and having problems, at this point I am going to say its the way your machining and not the material or the tooling used.
you didnt say what size KEO your using, where your drilling side of part top center line etc etc.
I would look for these things first, your spindle is junk or your using a hand drill, your holding the part by hand vs a vise or clamping it down, your drill chuck your using has way to much run out, your drilling on the side of the tubing in which case you need to end mill a small flat first. your speeds and feeds are way to fast.
if your drilling on the side use a endmill to spot the hole first, have the endmill mill a flat just a hair bigger than your center drill pilot.
Delw
Old 10-09-2009, 02:19 PM
Mcgyver is on a distinguished road
might not solve this particular problem, but if you are spot drilling, use a spot drill not a centre drill, centre drills are best left for making holes for lathe centres.
Old 10-09-2009, 03:12 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
FWIW, indexable spot drills are nifty tools. Use them to spot drill, chamfer, and I've even seen them used for engraving:
Cheers,
BW
Need Help!- Spot Drilling/Center Drilling Steel 55 HRC JWB_Machining General Metalwork Discussion 7 03-11-2009 01:35 PM
Problem- center drilling: Out of center skipper General Metalwork Discussion 8 03-01-2008 12:50 PM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
Drilling a hole in the center of a bolt / newby question stickben Mechanical Calculations/Engineering Design 1 04-30-2006 11:07 AM
what to do with center tap? truman General Electronics Discussion 21 01-20-2006 10:21 PM
