I've been cutting, (profiling) some stuff out of 10mm aluminium using a 4 flute endmill, as thats all I have (endmills). I was wondering If a slotdrill would be better for this type of work. I have no idea why, or when, a slotdrill should be used instead of and endmill, or endmill instead of a slotdrill. Can anyone enlighten me as what to use and when? Or even why? Thanks. Regards Terry..... |
| Using a 4 flute, when you are doing profiling and little stock removal is probably the right Joyce. Slotdrills main purpose is, when machining slots, like keyways in shafts, [full depth] they do a better job when it comes to metal chip clearing, or unloading your cutting edge. When doing "heavy cuts" on any other materials, incl. aluminum, it may be of benefit! Konrad |
| With a 4 flute mill you have twice as many flutes cutting which means you can run twice the feed rate. The 2 flute is basically for chip removal room in deep slots as mentioned above.
| Cheers guys. I'm having trouble with chips collecting in the milled channel. I plan on rigging up a compressed air line to follow the cutter. This should help blow out the chips. Also sounds like a 2 flute would help clearing chips. The channel is 3.75mm wide, 10mm deep. Thanks for the info. Regards Terry..... |
| I realise that this is a long time after your post, but a 2 flute endmill is always best when roughing out aluminum, carbide is best with through the spindle coolant, if possible. If through the spindle coolant is not possible, a horizontal machine will help, as gravity will help with chip removal. |
| 3 Flute High Helix Endmill Problem | Joe_CNC | General Metalwork Discussion | 7 | 07-19-2005 07:07 PM |
| Endmill runout | dberndt | General Metalwork Discussion | 14 | 01-27-2005 11:26 PM |
| Tool changing with endmill holders | febisfebi | General Metal Working Machines | 5 | 08-13-2004 12:33 AM |
| 3/8 Ball Endmill in Tool Steel | Freddy | Hard and High Speed Machining | 2 | 09-08-2003 03:13 PM |
