Old 10-04-2009, 10:25 AM
hack&wack is on a distinguished road
machining
hi,i run a hurco bmc 30 i have a run of 600 4140 castings.since it is somewhat a production run.i need to run them faster then it is running now.the casting is pie shaped with a 1.5 dia.boss1.912 dpw/a.250 rad at the bottom in the center which is where my program is slow.it is taking about a .25 to .312 of stock off.it seems like.3.ipm is about all i can get out of rougher.don't know if i should try taking it.125 cut & speed it up that way.any experience with this would be greatly appreciated.thanks
3d Machining elogicca LinuxCNC (formerly EMC2) 2 03-07-2008 09:51 PM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
3d machining MarshCustom FeatureCAM CAD/CAM 7 11-14-2007 04:49 PM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
One Hit Machining CRPDGAZ Hard and High Speed Machining 10 03-24-2004 01:52 AM
