Hello all, Recently I purchased a Sherline 4500 series mill w/ metric threads, I figured for most of the work I would be doing metric would be the best/easiest way to calculate measurements. But this thread isnt about what is better or worse, inch vs. metric. Rather it is about a bit of a pickle I am in. I few days after I picked up my mill I got a great deal on a sherline lathe, the probelm is the lathe is standard, but my mill is metric. I know I can change the threads at one point to get my lathe to metric, but in the mean time I have some blue prints of a basic steam engine that I would like to build as my first project, the plans are in metric scale, and most of the machining needs to be done on a lathe. So is it possible to just change all the etric measuements to standard? Will my tolernaces stay the same? Is just as simple as making the in calculations? Any help is apreciated guys Ashton |
| just divide all the numbers by 25.4 including the tolerances. this will convert imperial to metric. for metric to imperial multiply all by 25.4.
__________________ ___________________________________________________________________ http://www.cnczone.com/forums/showthread.php?t=86985 my work in progress |
#10
| Yes it is as simple as performing the conversions as has already been suggested. However you must keep one important detail in mind. Do not use a rounded off number in a series of subsequent calculations. For instance, adding a 4 place rounded off number to another rounded 4 place number can result in an error in the 4th decimal. It sounds trivial but in a series of calculations you can be miles off in your tolerance band. Gene |
#11
LOL., |
#12
| 0.50" x 25.4=12.7mm fwiw
__________________ JerryFlyGuy The more I know... the more I realize I don't (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| 30 Cal Gatling gun Blueprints | Nono | Hobby Discussion | 18 | 09-27-2011 09:32 PM |
| Doescanyone have blueprints... | brianklein | Hobby Discussion | 9 | 12-14-2009 11:33 PM |
| Problem- Threading Standard/Metric | Bill308 | General Metalwork Discussion | 6 | 02-06-2009 05:22 PM |
| X3 creating blueprints | timmydabull | Mastercam | 6 | 09-22-2008 12:10 PM |
| Standard tapping and Metric Programming. | Dull Tool | General Metalwork Discussion | 3 | 02-01-2007 04:09 PM |
