Old 09-22-2009, 03:59 PM
parkson is on a distinguished road
can an endmill cut longer than it's cutting length using multipass
Im trying to cut a 2in bar of aluminum in the VMC.
I am rounding the corners w/ a 3/4in dia, 3in cutting length endmill
I am getting chatter w/ any feedrate faster than 5ipm
Spindle is 1000rpm
Can I use a 3/4in dia but with a 3/4in cutting lenght for better rigidity and cut the bar using multipasses? Or will the sides of the endmill rub when I cut passed the 3/4in mark?
-Park
Old 09-22-2009, 04:45 PM
HuFlungDung's Avatar
Moderator
Yes, the shank of the endmill will rub unless you can grind it slightly undersize between where the flutes and and the chucking surface of the shank begins. If you have no facility to do this, you can carefully grind this 'neck' with an angle grinder or something, while the tool is running slowly in the spindle. Move the tool out of the holder a little so you don't mark the holder. Clean up the dust afterwards, and clean the toolholder too.
You don't have to radically undersize the tool, a couple of thousandths will suffice.
Old 09-22-2009, 06:11 PM
Jason S is on a distinguished road
Spindle is 1000rpm
-Park
Try leaving .005 for a finish pass or a spring pass at a slightly faster feedrate.
DANGER ZONE - HARD HAT REQUIRED!!!!
Old 09-22-2009, 07:41 PM
chuck5121 is on a distinguished road
Climb Cutting
Make sure you are Climb cutting, Leave .005 to .010 for a clean up pass, reducing the neck of the End Mill is a common practice you can use a Bench grinder, Angle grinder or a Cylindrical grinder. Good luck
Old 09-22-2009, 10:52 PM
little bubba is on a distinguished road
For chatter on something like that, toss the convention of slowing it down and taking a smaller finish out the window. Leave more stock for your finish, and feed it harder, leave yourself maybe .025-.030 and feed at .0025-.004 per tooth. Giving the endmill something to do(actually cut) won't let it chatter.
Back to the original question, yes you can, I do it a lot, even though your not supposed to. It kills your finish where the shank rubs. I'd never do it on a part that actually had to be tight on tolerance, or "shiny", then I'll either relieve the shank a bit (which relegates that endmill to that length of cut or longer for life) or Maritool has these cool little guys that are relieved about .005-.010 for the length of the shank so you can hang out as much or little as you need to. I keep a few of these guys on hand also.
http://www.maritool.com/Cutting-Tool...219/index.html
Harvey tool has basically the same thing, but they are relieved back to the next fractional size and are about 5 times the price and as far as the 4 flutes aren't variflutes/helix.
Longer parallel cable or longer steper wires? jvanick Hobbycnc (Products) 12 09-13-2008 05:51 AM
Plunge cutting indexable endmill orionstarman General Metal Working Machines 2 03-22-2008 07:50 PM
Table length cutting problem? Blacksunshine WoodWorking 4 03-13-2008 08:00 PM
Deep cutting Endmill guitarattack WoodWorking 1 05-27-2007 07:08 PM
1/32 Endmill cutting aluminum? DennisCNC General Metalwork Discussion 5 12-26-2005 11:22 PM
