i wanna buy an indexable carbide endmill for corner rounding. I want a 3/8" radius. Does anybody has try swiftcarb superbee or radstar or do you have another brand to sugest? It's exclusivly to work in aluminium. |
| R3/8" indexable ??? 2 flute -- a bit slow --- a fine finish with 1 or 2 passes may be difficult would be a lot cheaper HSCo corner rounder ( 4 flute ) and a lot more forgiving on the heavy cutting, and would last a fairly good length of time in Alum. and may be faster than the CBD |
| first of all, if you look to radstar, the size of the tip is only 1/2" the holder is 210$ and it is avaible in 3/4" or 1.250" shank you only need 1 insert at 42$. Also the same holder fit for radius from 9/32 to 3/8. I make a lot of part that have a linear contour from 38" to 125" rounded. So if i can feed twice faster, that tool will pay itself in short time. The swiftcarb superbee is a bit different. Tool tip is big enough (.750") but it is just 1/4" bigger than standar HSS corner rounding endmill. Holder costs 187$ and you need to insert at 27$ each. So the question is not Carbide or HSSco? But how does perform that kind of endmill in alu? |
| Boy, are you quick off the mark, didn't have that up long before editting ( didn't leave a comment to say I edited, it was that quick ) yeh, quick look at radstar told me my post was sh*t, and no-one likes mud in the eye, so I changed it Still those tools won't finish the rad in 1 pass, unless roughly formed in the hogging out stage, even then, it's a lot of arc contact all at once, may work quite good with the 2000, 3000 Alum grades maybe even the 5000, but it would struggle with 6061 and 7075 I would also imagine they would be quite noisey to use |
| Corner Rounding End Mill Help | Cartierusm | General Metalwork Discussion | 4 | 07-26-2009 10:30 PM |
| G76 Automatic Corner Rounding | Moparmatty | Okuma | 3 | 03-18-2008 04:14 PM |
| Corner Rounding on TM1 | JHamdan78 | Haas Mills | 11 | 08-14-2007 03:43 AM |
| corner rounding | sundy58 | FeatureCAM CAD/CAM | 1 | 11-22-2006 08:54 PM |
| corner rounding | inthedark | General Metal Working Machines | 7 | 02-07-2004 06:30 PM |
