Old 09-17-2009, 10:18 AM
plastibob is on a distinguished road
Removing broken drill
What is the best way of removing a broken HS drill without using an EDM machine? Thanks
Old 09-17-2009, 12:09 PM
stk2008 is on a distinguished road
is it possible to drill from the other side that way drill up to the drill bit then knock it out.
if no good will possibly have to spark erode it.
Old 09-17-2009, 01:52 PM
No it's a blind hole.
Old 09-17-2009, 02:08 PM
beege's Avatar
beege is on a distinguished road
What size drill? What material is it stuck in? How deep do you suppose?
Old 09-17-2009, 02:16 PM
It's a 5/32 drill in about 1 inch in aluminum 6061 broken off about 3/8" from the surface.
Old 09-17-2009, 07:51 PM
rowbare is on a distinguished road
Can you go in with a carbide end mill?
Old 09-18-2009, 12:38 AM
garagefela is on a distinguished road
Not really any help with the actual removal of the drill.
Depending on how the part is designed and if it is capable of it could you pocket out the material from around the drill so in effect you might end up with a 3/8" (or whatever) hole that could have a plug smacked and welded back in.
Then re drill the hole.
I suppose if you are going to stuff around that much just give the part to a company that spark erodes stuff out, they are out there. Or get friendly with someone that has one.
Sorry not much help with the actual drill part but just another option.
Cheers M
No, Little-Johnny, pomegranate is not a type of English stone.
Old 09-18-2009, 01:39 AM
Arquibaldo is an unknown quantity at this point
this might work
I remembered reading somewhere that certain chemicals will dissolve the steel while
preserving the aluminum... I googled and, sure enough, found:
http://www.atmlist.net/pipermail/atm...ch/007034.html and
http://www.atmlist.net/pipermail/atm...ch/007035.html and also
http://www.ytmag.com/articles/artint62.htm
I have no idea whether this will work, but you might try on a piece of scrap...
Nelson
Old 09-18-2009, 04:15 PM
I'm going to try using carbide. I can't cut around it. Worst case I'll have to EDM it
Old 09-21-2009, 05:42 PM
Mcgyver is on a distinguished road
if its in AL, just dissolve it out with Alum
  #11   Ban this user!
Old 09-21-2009, 09:17 PM
kazikw is on a distinguished road
Don't cur around it. Use scrap carbide end mill. Sharp like shamfer tool 45 deg. Go slowly like with feed 3. in center of drill with rpm 300. For sure 1 carbide tool will be not enough but they are already scrap.
  #12   Ban this user!
Old 09-23-2009, 10:02 PM
Thanks for the tips, I ended up milling around it and plugged it. Barely had the room - thin walls but I salvaged it and it worked out fine.
Removing aluminum stock fast or drill vs end mill... zaebis General Metalwork Discussion 7 09-03-2009 11:03 PM
removing the chuck shaju Daewoo/Doosan 4 06-09-2009 07:20 PM
Extracting Broken Drill Bit Crashmaster General Metal Working Machines 9 04-24-2008 01:37 PM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
fanuc drill mate / robo drill post for enroute? goodplastics Post Processor Files 0 07-19-2007 05:49 PM
