Old 09-16-2009, 04:06 AM
bubblybill is on a distinguished road
Square hole in square tube
I have no idea what Im doing! I dont have any engineering background and I havent worked with metal as Im mostly wood orientated, So I could really use your advise/help.
Im designing a cnc wood router and I would prefer the frame to be made from steel. I need to make a bracket to align the rail but I dont know how to go about cutting a square hole in a rectangular box section of mild steel
Please forgive my attempt at drawing, but It probably better than me trying to explain in words
Any ideas, help, or humorous comments welcome.
I wouldnt use a hammer to put a screw in as I do have some technical ability but could really use some help.
Thanks in advance
Name:	good idea bad drawing.jpg‎
Precision is something that can be achieved when you dont have a budget like mine
Old 09-16-2009, 08:38 AM
Get the smallest fine tooth saber saw blade you can find. Drill a hole just large enough to take this blade at opposite corners of your square hole location and cut it out with a saber saw. Go slowly and use some tapping fluid as a lubricant; if the lubricant starts smoking you are running the saber saw too fast.
Old 09-16-2009, 09:46 AM
Superman's Avatar
Superman is on a distinguished road
2 other methods
--mark out the square, drill out on the corners ( they need clearance anyway ), hacksaw the lines as Geof suggests
or
--mark out the square, cut across the diagonal corners, mill in a vee in both parts and then clearance drill the top, tap the bottom for bolting together
Old 09-16-2009, 11:24 AM
Thankyou for advice, Looks like my design will be born after all !
Old 09-19-2009, 10:14 PM
Mcgyver is on a distinguished road
there are ways to cut a square hole, but because of the challenges good designs tries to avoid them unless absolutely necessary....maybe have a round hole and an adapter that fits inside it and insidethe square tubing (brazed maybe)?
Old 09-19-2009, 11:02 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
if you have a drill press handy then you could easily lay out the square then drill with a 1/8 dia drill bit all along the layed out lines , then clean it up with a die grinder or file
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 09-20-2009, 10:18 PM
youngjim is on a distinguished road
If you can leave a bit of a radius at each corner then it'll be more resistant to cracking from flexing. Either leave a bit of material at each corner (i.e. don't file it square) or drill a small hole centered on each corner if the design permits.
Jim
No time to do it right, plenty of time to do it twice.
Newbie- Square tube verses round? David Lucas DIY-CNC Router Table Machines 20 07-22-2009 08:13 AM
Square Tube Welding Done Right! boguski.1 Welding, Brazing, Soldering, Sealing 12 09-30-2007 12:13 AM
square hole? 55 dude General Metalwork Discussion 3 03-04-2007 01:01 PM
Looking for 2" square steel tube. danmickey DIY-CNC Router Table Machines 3 11-15-2005 05:22 PM
Square Hole DLMACHINE General Metalwork Discussion 20 04-26-2005 08:39 AM
