Old 09-14-2009, 10:05 AM
toolsharpener is on a distinguished road
Machining A-36 material
I am looking for feed rates on reaming A-36 material, or what is it close to?
Thanks.
Old 09-14-2009, 01:11 PM
DSL PWR is on a distinguished road
A 36 is just standard structural plate, so feeds and speeds for 1018 should work just fine. The only thing that might get you is mill scale on the outside of the part (much harder and abrasive). If it has been faced off you should be good to go!
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 09-14-2009, 01:16 PM
Thanks, this is good news.
Newbie- Material and Machining questions rolinger General Metalwork Discussion 1 03-19-2009 09:57 PM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
on Gildemeister speed 12 -7 hard material machining Ashu Hard and High Speed Machining 0 10-16-2006 07:14 AM
Machining anodized parts or anodize after machining? SRT Mike General Metalwork Discussion 4 03-11-2006 11:22 PM
Machining TZM material, anyone? home-tek General Material Machining Solutions 2 01-16-2006 08:04 PM
