| Heavy Metal: Yes it is possible. Both Exterior and Interior NPT threads. I am not sure what size you want to do, nor do I know what type of threadmill that you have access to, but this is an example of a 2"-11 1/2 I.D NPT thread using a 5/8 diameter shank threadmill, with .82 cutting dia. The insert is a 21mm height -11 1/2 pitch , 4.7mm thick, and 12mm from back of insert to end of teeth . (The insert is specific to the pitch of thread.) So if you have a single point, this would not work for you. But single point thread milling can be done as well with some modification. % O1234 (X=0,Y=0 ORIGIN) (NO TOOL RADIUS COMPENSATION D1=0) T1M6 G90G0G54G17G43H1X0.Y0.Z1.9685S2338M3 G1Z-0.7674F196.9 M08 G91G01G41D1X0.3747Y-0.3747F6.6 G3X0.3747Y0.3747Z.0109I0.J0.37468F4.3 G3X-0.7494Y0.7500Z.0217I-0.75004J0. G3X-0.7507Y-0.7500Z.0217I0.J-0.75071 G3X0.7507Y-0.7514Z.0217I0.75139J0. G3X0.7521Y0.7514Z.0217I0.J.75207 G3X-0.3760Y0.3760Z.0109I-0.37603J0. G1G40X-0.3760Y-0.3760F196.9 G1Z0.6739 G90X0.Y0.Z1.9685 M30 % ***I HAVE A PROGRAM YOU CAN USE TO THREADMILL ANY ID/OD THREAD GIVEN FROM A MANUFACTURER & DEALER OF THREADING INSERTS & TOOLS. I USE THEM ALL THE TIME. IT HAS A POST PROCESSER BUILT IN TO POST YOUR PROGRAM, SO JUST FOLLOW THE WIZARD AND CUT YOUR THREAD! I SENT IT TO YOUR PM. |
See link below..... http://www.carmex.com/downloads.php?instance_id=18 Left side of page, where it says Mill-Thread software.... click here, download and enjoy. |
| HI, JUST BROWSING AROUND AND SEE THAT YOU HAVE A TAPER THREaD MMILLING PROGRAM.WOULD YOU SHARE THIS WITH ME OR TELL ME WHERE I CAN GET IT THANK YOU awalters21@earthlink.net |
| Tags |
| tapping, thread milling |
| Need Help!- NPT Taper-to-Straight-to-NPT-Taper Thread | bdyenter | General Metalwork Discussion | 2 | 09-16-2009 08:10 AM |
| Need Help!- 1/4-18 PIPE THREAD | Get lucky | G-Code Programing | 18 | 02-04-2009 05:45 AM |
| Need Help!- Thread Milling a Taper | automizer | G-Code Programing | 19 | 06-12-2008 10:23 PM |
| Help with converting the tapping data to American taper pipe. | custer | Mazak, Mitsubishi, Mazatrol | 2 | 09-14-2007 09:28 PM |
| Pipe Thread | harley88 | Haas Mills | 2 | 11-29-2005 10:43 AM |
