Old 09-14-2009, 09:19 AM
bdyenter is on a distinguished road
Smile NPT Taper-to-Straight-to-NPT-Taper Thread
You're probably thinking "What is this guy talking about?"
I have a job to tackle that is a bit different then the normal than just a NPT Taper thread or Straight Thread. A bit more complicated....... Want to see if anyone has tackled something similar.The job to make conduit for the electrical industry and they need something specific.
Customer is asking for a 4" NPT Taper on 1st end of shaft that will continue threading to a 4" NPTS Straight Thread then back to a 4" NPT Taper for the other end of the shaft. The NPT Taper threads on each ends are standard engagment, but the main thing is to be able to thread a 4" NPTS straight thread coupling all the way across the entire shaft which is 7" O.A.L.
You might ask....... "if using a 4" NPTS straight coupling, then why thread taper the ends?" Reason is because they still use a locknut inside the elect. boxes that need a handtight engagement.
So.....
1) I have chucking stock to be able to thread entire 7" length. I will set up using my tailstock on one end and 7 1/2" out of chuck for threading.
2) I know I probably can't use a G76 cycle for this because of the amount of variables here. Probably have to use a G32 cycle if not mistaken.
I have not written G32 cycles for threading in the lathe. Mostly G76
2-line cycles for all threads. That is why I ask for some help.
So program would have to start a G32-- 4" NPT Taper, then continue threading a 4" NPTS straight thread across the shaft, and lastly, another 4" NPT Taper thread downward to the end of 7" O.A.L of shaft.
Old 09-16-2009, 06:34 AM
g-codeguy is on a distinguished road
PM sent.
Old 09-16-2009, 08:10 AM
samco is on a distinguished road
I don't know what kind of machine you have...
This is sort-of similar. (and probably a bit more complicated) But might give you some ideas.
(emc2)
http://jmkasunich.com/cgi-bin/blosxo...k/fusee-1.html
Need Help!- How to machine an adapter to convert taper shaft to straight kola General Metalwork Discussion 11 07-15-2011 10:39 AM
Need Help!- Thread Milling a Taper automizer G-Code Programing 19 06-12-2008 10:23 PM
Newbie- taper thread cutting cncmc Mazak, Mitsubishi, Mazatrol 4 05-05-2008 04:59 AM
taper thread gcrandall Mazak, Mitsubishi, Mazatrol 4 05-17-2006 10:13 AM
R8 taper lt paul General Metal Working Machines 2 06-10-2004 10:31 AM
