Old 09-09-2009, 12:27 AM
ryansuperbee is on a distinguished road
question about electric motor starting up on lathe
Hey guys. I have a medium sized lathe and I was wandering if there is an easy way to make the motor come on "slowly" intstead of just taking off really fast. I'm looking for a way to make my lathe motor come on more like how a bench grinder comes on, nice and slow. Is there some type of resistor or capacitor that would make this happen? Thanks!
Old 09-09-2009, 07:49 AM
Al_The_Man's Avatar
You did not say what kind of motor you have, if single phase induction motor then there is not much out there, you can go with a 3 phase motor and a VFD.
Old 09-09-2009, 09:14 AM
The only reason a grinder spins up nice and slow is that it is a small motor turning a large rotating mass with a lot of rotational inertia being spun up to 3400 rpm in direct drive. The lathe is often a bigger motor spinning the rotating mass up to a much lower speed through a reduction belt drive.
Al's suggestion for a VFD will work but will be a lot of dollars and a possibly less expensive option may be to get a small centrifugal clutch on the motor pulley. This allows the motor to come up to speed faster but the lathe takes a bit longer.
Tags
electric, lathe, motor
Dumore electric motor questions Steve F General Metalwork Discussion 2 07-15-2008 01:45 AM
Question on shimming electric motor LewisCobb General Metalwork Discussion 4 06-28-2008 11:47 PM
Most efficient electric motor? DennisCNC General Electronics Discussion 2 06-10-2008 11:14 AM
Electric Scooter Motor any good? chola Mini Lathe 21 03-27-2007 12:52 PM
Electric motor question bbergami WoodWorking 21 01-29-2006 07:07 PM
