I'm using my cnc lathe to cut a large quanity of delrin bushings. I need to hold and internal dia. within plus or minus .001 . I'm using my regular Kennemetal boring bar inserts that I use for cutting stainless and alum. It's working but I'm finding that I have to change the internal dimension about ever 3 parts. I'm running it at 2000rpm. Any ideas for me out there. Thanks Sue |
| not knowing how exactly your holding or the size, I am guessing 2 things heat and or chuck pressure. those 2 things alone will cause you problems. I have used regualr inserts in a pinch and have no problems with tolorance issues .001 is nothing, providing the part has some stock. but all the parts would be the same not just every three so that leads me to chuck pressure and heat issue. chucking is 90% of tolorance problems on plastic and its never the same I preferr positive inserts, I like ccmts with a .015 rad best |
| Need A Quote- RFQ Small delrin part suitable for cnc machining | rodjava | Employment Opportunity | 23 | 07-25-2009 04:27 AM |
| Problem- Machining Delrin | KonradyTom | General Material Machining Solutions | 1 | 12-24-2008 11:15 AM |
| Need Help!- Newbie Looking For Cheap Machining (Alum/Delrin)Done (I Live in Japan) | TheHeadHunter | Parts for Radio Control Models | 1 | 06-12-2008 10:45 AM |
| MIS CNC Machining and tooling - General machining - Thermoform Molds | modernprecision | Employment Opportunity | 0 | 11-23-2007 10:05 PM |
| Delrin | patriotswan | General Metalwork Discussion | 5 | 03-29-2007 09:04 PM |
