Hello, Could someone help me with creating a variable program In G code using variables #500 and above. The part is a Tapered Roller for a Tapered Bearing. i can send a pdf. of the print email me at jdp@kingsbury.com Here is the code generated by smartcam for the part to be made the variables i'm looking to use are. 1. length of part 2. Dia. and taper angle 3. back face radius driven by taper angle 4. corner radius 5. counterbore depth, dia. is driven by tool used 6. thru hole is driven by tool used 7. material is 8620 steel 8. i would like to create a straight roller with no back face radius also from this program by simply setting values to 0 or some value. (MSG, 69556-3.EIA 1.25" X 2.35" TAPER ROLLER K069556-3M BHB 08/26/09) G0 G18 G20 G40 G53 G80 G96 G99 G111 G30 U0 G30 W0 G99 G111 G50 S4000 R1 M901 N10 T1010.03 G96 S660 M4 R1 M8 (MSG, WALTER DWLNL 16 4 D HOLDER- FACING UP AND LEFT) (MSG, ROUGH TURN LEAVING .015") G0 Z0.1 X1.7 Z0.015 G1 X-0.062 F0.02 G0 Z0.1 X1.4537 G1 Z-2.63742 X1.5 G0 Z0.1 X1.7 X1.1538 G1 Z-0.00012 G3 X1.36004 Z-0.15036 I-0.05788 K-0.15024 G1 Z-0.18059 X1.35991 Z-0.18503 X1.21031 Z-2.63742 X1.4537 G0 Z0.1 X1.7 G30 U0 G30 W0 M1 G99 G111 G50 S4000 R1 M901 N20 T0202.01 G96 S700 M4 R1 M8 (MSG, WALTER DWLNL 16 4 D HOLDER- FACING UP AND LEFT) (MSG, FINISH FACE AND TURN - HD1) G0 Z0.1 X0.44625 Z0.05238 X0.42192 G1 X1.0904 Z-0.00656 F0.012 G3 X1.32991 Z-0.15378 I-0.02518 K-0.1428 G1 X1.17944 Z-2.62046 G0 Z-2.505 X1.37946 Z0.1 G30 U0 G30 W0 M1 G99 G111 G50 S4000 R1 M901 N30 T0606.01 G97 S3000 M3 R1 M8 (MSG, NINE-9 CHAMFER TOOL) (MSG, SPOT FOR DRILL) G0 Z0.1 X0.0 G1 Z-0.177 F0.0033 G0 Z0.1 G30 U0 G30 W0 M1 G99 G111 G50 S4000 R1 M901 N40 T1212.01 G96 S80 M3 R1 M8 (MSG, -J- (.277) HSS DRILL 2.4" MIN FLUTE LENGTH) (MSG, DRILL THRU) G0 Z0.0 X0.0 G1 Z-0.65 F0.003 G0 Z0.0 Z-0.6 G1 Z-0.85 G0 Z0.0 Z-0.8 G1 Z-1.05 G0 Z0.0 Z-1.0 G1 Z-1.25 G0 Z0.0 Z-1.2 G1 Z-1.45 G0 Z0.0 Z-1.4 G1 Z-1.65 G0 Z0.0 Z-1.6 G1 Z-1.85 G0 Z0.0 Z-1.8 G1 Z-2.05 G0 Z0.0 Z-2.0 G1 Z-2.25 G0 Z0.0 Z-2.2 G1 Z-2.45 G0 Z0.0 Z-2.4 G1 Z-2.49322 G0 Z0.0 G30 U0 G30 W0 M1 G99 G111 G50 S4000 R1 M901 N50 T0707.01 G96 S205 M3 R1 M8 (MSG, .625" C.E.M.) (MSG, SPOTFACE PER PRINT) G0 Z0.0 X0.0 G1 Z-0.037 F0.0016 G0 Z0.0 G30 U0 G30 W0 M1 G99 G111 G50 S4000 R1 M901 N60 T0303.01 G97 S1200 M3 R1 M8 (MSG, SECO CFML 100 05D W/SECO LCMF 160505-A187-MT CP500) (SET Z TO RIGHT SIDE OF TOOL) (MSG, BACK END RADIUS AND CUT-OFF- HD1) G0 Z-2.355 X1.7 X1.52992 G1 X0.76071 F0.003 X1.48992 G0 Z-1.94426 X1.30695 G1 X1.19707 Z-2.25584 G3 X0.96071 Z-2.355 I-0.11818 K0.02084 G1 X-0.04 X1.48992 G0 X1.7 G30 U0 G30 W0 G28 B0 M1 M99 |
| Need Help!- Sample EIA program for Mazak lathe | extanker59 | Mazak, Mitsubishi, Mazatrol | 5 | 10-24-2011 08:16 PM |
| Need help understanding a program Fanuc 6t on a Mazak lathe | mgb1974 | Fanuc | 15 | 07-31-2009 03:48 PM |
| Testing program for Macro (Fanuc Macro B) | NickDP | Fanuc | 2 | 03-27-2009 03:15 PM |
| Need Help!- Mazak macro | bill52 | General Metal Working Machines | 3 | 10-01-2008 12:44 PM |
| Macro/Parametric Programming | screensnot | Fadal | 4 | 03-28-2005 08:45 PM |
