Hello I have a mazak QT15, when I turning out along i have not sheer face and outside diameter. This is not mechanical problem, the same I show in graphic display. I dont wont what is a problem. If anyone knows what is this. Please help me. Bert |
| I programming "bar out" or "bar in" In this I have 2 option turning along or across in 1 choice I have otside diameter cylindricall but I havn't a right angle to a face, If I porogramming turning across I have right angle betweean spindle axis and turning face but in otside diameter I have a taper. The same I have in grapfics display |
| in bar in, out, and bar face modes you start by selecting a linear move or a taper move. In a linear move you describe x and z coordinates of where to finish, In a taper move you describe x and z coordinates of the start and finish points of the cut. If you are boring a straight hole, and turning a straight outside diameter, you can use Linear moves. ( I think you are currently using taper) If you want a chamfer or radius at the start of the cut there is a "start cnr./rad" entry field before the x and z coordinates. for instance to turn a 2" bar to 1.8" O.D 3" long You can use the LIN BAR OUT start point x 2.0 start point z 0. speed feed Rtool Ftool LIN cnr____ x_**_ z_**_ x_1.8_ z__3.__ final cnr._____ etc. etc. to turn a taper from 1.8" to 1.85" use the Taper BAR OUT start point x 2.0 start point z 0. speed feed Rtool Ftool Taper cnr____ x_1.8_ z_0._ x_1.85_ z__3.__ final cnr._____ etc. etc. It has been a few years since I have seen a mazatrol T32 controll, so excuse me for not being so accurate on the format Keep trying, It is extremely simple format when you figure it out. I wish I still had a Mazak, The last three shops I worked In had Mazaks Mills and Lathes, the mill controlls are alright, but the Lathe controlls are bad ASS!! |
| Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english | tuanpq | Mazak, Mitsubishi, Mazatrol | 21 | 01-21-2012 07:33 PM |
| Need Help!- Mazatrol T-3 | robind | Mazak, Mitsubishi, Mazatrol | 9 | 06-19-2009 12:52 PM |
| mazatrol cam M2 | spickett | Mazak, Mitsubishi, Mazatrol | 3 | 03-25-2008 07:34 AM |
| mazatrol T1 Qt 20 | nastek | Mazak, Mitsubishi, Mazatrol | 1 | 02-16-2007 07:46 AM |
| does m-cam do mazatrol? | underdog | Mastercam | 2 | 10-11-2005 09:30 PM |
