Old 09-01-2009, 05:21 PM
simonfilm is on a distinguished road
Glanze 12 mm boring tool
Two weeks ago I bought online at www.chronos.ltd.uk a Glanze 12 mm boring tool (Ref: XC37): http://www.chronos.ltd.uk/acatalog/C..._Tools_77.html
Since my lathe uses 12 mm tools. I understand a 12 mm tool is a tool put the bit of the insert at a heigth of 12mm from the toolpost floor, so the bit is exactly at the axis of the lathe.
The tool they send me has a heigth of a bit more than 5 mm, so I have to put plates below in order to get the axis at 12mm.
The question is: is an error of them because a bad specification or there is something I dont know and is my fault. In order to complain for a change.
Thank you very much!!
Old 09-02-2009, 08:06 AM
chalky is on a distinguished road
The 12mm probably refers to either the diameter of the boring bar or the smallest hole the bar will fit into.
Old 09-02-2009, 08:31 AM
dcook is on a distinguished road
Is 12mm not the diameter of the bar? Boring bars are typicaly sized by their shank diameter and as previously mentioned the minimum hole size they will go into. The offset from the centerline of the bar to the cuting edge tip is a given specification of the bar and unique to it.
Experience is what you get when you don't get what you want.
D'Andrea boring head, Solid Carbide boring bars etc. morehelium EBAY ADS 1 08-24-2009 11:19 AM
HF 7x10 boring/tool help fpm Mini Lathe 10 07-14-2009 08:58 PM
Boring Tool as an end mill? SV in SD General Metal Working Machines 57 01-30-2008 08:50 AM
Boring and Turning with the same tool? Donkey Hotey Haas Lathes 14 12-13-2007 08:45 AM
Which boring bar? kong General Metal Working Machines 25 06-26-2004 05:56 PM
