Old 09-01-2009, 12:53 PM
vertix19 is on a distinguished road
Lightbulb the best way to machine iron castings
hello every body i was wandering if someone with experience machining casting in cnc can give some advice about drilling and hard milling, castings like iron and stainless steal, should one use coolant or not or what kind of insert? any help will be greatly appreciated. thank you very much
Old 09-03-2009, 08:22 AM
kling8 is on a distinguished road
i'd say you want to use coolant for sure, as far as the type of insert, there are a ton of them out there, in a tooling catalog they do a pretty good job of describing the application for the various inserts. type of metal machining, if your slotting, plunging, pockets, profile, general purpose, all things to consider when trying to find the right insert. and a lot of times you pay for cheap tools are usually just that.
Old 09-03-2009, 10:00 AM
Boots is on a distinguished road
Cast Iron and Stainless take different types of inserts. I used to use Ceramic inserts on cast Iron (milling) with NO COOLENT. But you can't let your parts get too hot as they will be out of tollerance. Ceramic Inserts don't do well against Cast Stainless. If you contact a sales rep. he will come to your shop and help you figure out just what you need. Save yourself all the headachs and let them do it.
We all live in Tents! Some live in content others live in discontent.
open source cast iron box way benchtop milling machine ihavenofish Benchtop Machines 567 05-24-2012 02:14 PM
Investment castings indianseller Casting Metals 1 07-18-2008 10:06 AM
Estimating Castings Gene0552 Casting Metals 1 03-06-2007 08:03 AM
CNC Mill and CNC Lathe offered. Aluminum and Gray Iron Castings maquiza Employment Opportunity 0 12-31-2005 10:37 AM
Why is a heavy iron base vital for a good machine? Com Mechanical Calculations/Engineering Design 26 11-29-2005 09:41 AM
