Old 08-31-2009, 06:48 PM
zaebis is on a distinguished road
How to make a sharp corner on a mill?
Vertical mill, rectangular poket bt 3x4" 1" deep need to mill it with sharp corners. How?
Old 08-31-2009, 06:58 PM
PoiToi is on a distinguished road
How sharp is "sharp"??
You can use progressively smaller endmills to get to the corner radius you need (no matter what you do, there is ALWAYS gonna be a radius. even if it's .00001, it's still there)
Or use small drills at the corners first, and then mill the pocket.
You can rough it out and file down the corners by hand...
I think if you tell us more info there are many namy members who will have great ideas.
Old 08-31-2009, 07:19 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Can you cut pockets in the corners?
http://www.omwcorp.com/img/cutawayco...ket600x514.jpg
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 09-01-2009, 12:58 AM
ya that is what I thought. Thanks will have to settle for this workaround.
Old 09-01-2009, 06:47 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
It is an EDM job if you can't pocket the corners.
www.integratedmechanical.ca
Old 09-01-2009, 11:28 AM
can EDM cut a pocket? e.g. carve 0.5" deep of 1" thick stock? not through !!!
Old 09-01-2009, 11:55 AM
beege's Avatar
beege is on a distinguished road
Ram EDM
Old 09-01-2009, 12:31 PM
DareBee's Avatar
Of course.
I do it all the time.
I also have tapping rig, amazing how many people need tapped holes in hard material.
Old 09-01-2009, 04:51 PM
palenn is on a distinguished road
Shape cutting
Making a square broach to fit in the mill spindle might be a way to approach the square corners. A piece of 1/2" drill rod, for example, milled to a square shape on one end and then hardened could be used in the mill spindle as a broaching tool moving the spindle up and down by hand while feeding the X and Y axis in small increments. This method is sometimes used in lathes for making blind keyways.
An alternative to making your broach out of round stock would be to use one of these sleeves to hold a square HSS lathe tool http://http://www.sturdybroach.com/products.nxg
Old 09-01-2009, 11:17 PM
Charlie Gary's Avatar
Charlie Gary is on a distinguished road
Be sure to ask your boss if it's ok to use the spindle bearings as a press. Most will freak out.
Later,
Charlie
Old 09-02-2009, 06:47 AM
DareBee's Avatar
This method works, but you will not get a good bottom.
For lack of not wanting to type big explanation for many variables, you will end up with a material pile under the broach that will not shear (remember this is a blind pocket). This could be as much as 1/4" considering you are working a 1" deep pocket and envisioning normal cutters and cutting practices for the initial milled pocket.
  #12   Ban this user!
Old 09-02-2009, 10:41 AM
Try "googling" cherrying or cherrying head.
Dick Z
DZASTR
Sharp Mill retrofit RJ. Vertical Mill, Lathe Project Log 39 03-12-2011 12:58 AM
Corner Rounding End Mill Help Cartierusm General Metalwork Discussion 4 07-26-2009 10:30 PM
Is this possible to make? (Rectangular inner cutout with sharp corners) PhoenixMetal Benchtop Machines 46 11-25-2008 07:01 AM
Corner Rounding END MILL Tool Paths S&F? ohallock Machinist Feedback 1 02-18-2008 05:30 AM
Making a sharp inside corner? Docmani General Metalwork Discussion 10 11-14-2005 11:26 AM
