Old 08-31-2009, 12:09 PM
fenix728 is on a distinguished road
Unhappy machining Brass 360
hello everybody i am making this simple part out of brass 360 and i am leaving .01" per side to finish the ID but i get chatter even when i am going 700 rpm and .004" ipm my boring bar is .5 and is sticking out 4.3" carbide. can anyone please tell me how i can get rid of chatter, should i leave more stock for finish or feed faster or slow the rpm even more, the worst chatter is at the front where the cilindric wall is .065" thick an i am using a .0156" TNR insert, thankyou for all your help and time.
Old 08-31-2009, 02:14 PM
PoiToi is on a distinguished road
Try leaving more stock, going faster, and pushing the boring bar as hard as it will go while holding your surface finish reqs.
A part like that should only need one boring bar pass after the drill.
If you have a bar with a smaller TNR, that will help too. (less pressure in the cut). On that note, make sure your bar is SHARP!!! brass cuts like butter, the sharper the edge, the better the actual cutting action will be, instead of shearing the material.
Also, bore before you turn. this should help too.
Old 08-31-2009, 08:35 PM
ViperTX is on a distinguished road
Are you boring on a mill or lathe. I suspect the problem is the stock is flexing the most where it is unsupported...which is the front.
Paul
Old 09-01-2009, 04:49 AM
jeffrey001 is on a distinguished road
For such a light cut, I would use HSS boring bar with a very sharp bit, carbide are not very good taking very light cut in brass.
Jeff
Old 09-03-2009, 11:50 PM
Crapmuffins is on a distinguished road
Your boring bar is an 8.6-1 ratio which is over the standard maximum for a carbide boring bar (6-1) It's possible to go over the max ratio to 10-1 by tuning the rpm to cancel out the frequency of the bar's resonance. http://askblueswarf.com/showthread.php?p=4#post4
Old 09-06-2009, 06:50 PM
Metalmanti is on a distinguished road
Move the boring bar as close to the tool holder as possible so you can still bore the part. Also use a .007 TNR insert. You might also try slowing down your feedrate. Depending on the size of the part you can also wrap rubber or lead around the OD to help damp out the vibrations.
Old 09-14-2009, 10:30 AM
toolsharpener is on a distinguished road
have you tried reaming?
machining brass plate woodman08 Gorilla CNC Machines 0 10-28-2008 12:21 AM
Help machining C260 brass plate. 68rustang General Metalwork Discussion 4 08-03-2007 02:34 PM
Machining brass I beams. tirebiter General Metalwork Discussion 8 04-26-2007 04:51 AM
Recycling / Melting / Casting 360 Machining Brass KSKID Casting Metals 4 02-15-2007 03:58 PM
Machining brass and it...bends? distorts? (new guy) snapman General Metalwork Discussion 4 10-14-2005 08:01 AM
