Old 08-30-2009, 07:02 AM
MechanoMan is on a distinguished road
G-code step-and-repeat
OK, I have an L-shaped part which is just a load of G-code in a subroutine.
I will need to do a step-and-repeat where I rotate the part 180 deg and XY offset it enough to clear the previous part.
G68 rotates the coordinate system. But it also says it rotates the work offset, which would be horrible.
G10 can set the origin and G52 can do a temporary offset... but Mach3 says G92 offsets CANNOT be used with G52. Which would be a problem.
I'm really frustrated. I can't remake the G-code as relative moves or anything, it's CAM-generated. The idea was to do a M98 call of the routine, rotate the coordinate system 180 deg and XY offset, then call again (lather, rinse, repeat). But is this even possible??
Should I maybe try to get the work offsets from the parameter list, zero the actual offsets, rotate the system, then reassign the work offset along with the necessary XY stepping?
Old 08-30-2009, 07:18 AM
Karl_T's Avatar
Karl_T is on a distinguished road
More than one solution here. On my control (not Mach), I'd set up work offsets for each part - G54 for part 1, G55 for part 2, and so on. Then just do your new offset and rotate before the routine call.
Karl
Old 08-30-2009, 09:26 AM
TOTALLYRC is on a distinguished road
If the part is relatively simple and you are trying to "nest" them to make better use of the available stock,then I would draw out the layout you need in the cad program and then run it through the CAM again.
Old 08-30-2009, 10:16 AM
HuFlungDung's Avatar
Moderator
I' ve never used coordinate system rotation, but have you played with it to see if rotating the work offset is 'horrible' or not? It may be a matter of what you think is going on, and what really goes on are two different things.
In my mind, I can sort of visualize that not rotating the work offset could in fact, be a problem, depending on which coordinate systems are active.
I'd take the sure route and program a right and a left, and then repeat that, rather than dealing with a bunch of complexity.
Old 08-30-2009, 04:17 PM
Not gonna happen. CAM is a difficult process and requires some post-editing. Depending on what I have for stock, I may step-and-repeat different ways.
Oh yeah it's horrible. See I've got a hole I align for the origin. So I run the machine over the stock where I need that to be, and use G92 to set that as origin, say it's actually X=5.123 in machine coords (I never use machine coords at all). Well, that moves the origin way the hell over in the wrong direction when the code tries to do a G68 rotation from part 1 to part 2. Basically the 180 deg rotation moves the ORIGIN to X=-5.123 on machine coords.
The G52 Temporary Offsets look like they have the same sort of problem, it clobbers the original work offset. So you try to step over 1" by saying G52 X1, but that clobbers the G92 offset, putting it at MACHINE coord X=1, meaning the G52 X1 resulted in a relative move by X-4.123, and it's unpredictable at that, since changing stock and resetting the work offsets will totally change what the G-code does.
Old 08-31-2009, 03:42 AM
Ah-ha, it IS possible! I was a bit confused initially, betwen G92 offsets and WORK offsets. I didn't realize how they were different.
This allows me to start with a G92 offset and offset angle (used when the stock doesn't totally line up with the axis), and restores them when done.
The only thing is, if you see a problem in the run, pull a Stop, and then start again from the beginning, you will have corrupted offsets. If you didn't have any G92 or angular offset to begin with, then can just zero them and restart. As such I'd kinda recommend not setting up with stock with G92 offsets but by setting the Work offset, and avoiding using the angle if you can.
This took way too many hours to figure out...
Code:
#100=#5211 (initial G92/G52 x-offset, #5211 is a Mach3 system param)
#101=#5212 (initial G92/G52 y-offset, #5212 is a Mach3 system param)
#102=0  (incremental rotation, Mach3 will not provide the initial offset so there is no way to figure it out, but by doing incrementals and recording the change alone, that'll allow us to work off it and restore it)
#10=0        #11=0  #12=90  M98 P5
M98 P2 (O2 is the part to be repeated)
#10=[#25]  #11=-50 #12=-90 M98 P5
M98 P2
#10=[#50]  #11=0  #12=90  M98 P5
M98 P2
(cleanup at end)
G52 X[#100] Y[#101]      (restore original G92/G52 offsets)
G68  a0 b0 r[-1*#102] i0 (undo any previous inc rotation)
M30 (end of program)
O5 (Step, Rotate, and Repeat Offset)
(#10=x offset, #11=y offset, #12=angle)
G52 X[#100+#10] Y[#101+#11] (XY stepping)
G68  a0 b0 r[#12] i0  (set inc rotation)
#102=[#12] (remember new inc rotation state)
M99
Old 05-20-2012, 06:45 PM
garym1957 is on a distinguished road
Well I'm not proud. I'm just gonna ask someone to show me how so I can get some actual cutting done.
(I'm trying to surface a spoilboard)
N0 G1 X20.0 F80 (Run 20 inches to the right)
N1 G1 Y+=0.0100 (Increment Y by some partucular amount?)
N2 G1 X0.000 (X back to zero)
N3 G1 Y+=0.0100 (Increment Y again)
N4 G? N0 L30 (repeat the whole mess 30 x)
Any takers?
Or point me in some direction, please.
whole G-Code REPEAT command ?? LockTech G-Code Programing 14 08-08-2010 10:21 AM
g code for repeat the previous move woffler G-Code Programing 6 03-26-2008 10:07 PM
Step by step 3d wireframe Stl. to G-code josh cbr900 Mastercam 7 11-12-2007 05:43 AM
AVR G Code Interpreter/ Step-Dir Macro Recorder bitmannz General Electronics Discussion 5 02-01-2007 12:07 AM
Repeat g-code with y offset tpaulson G-Code Programing 19 11-29-2004 01:36 PM
