Old 08-29-2009, 02:36 AM
Cartierusm is on a distinguished road
Tapping Real Deep How?
I'm making a fixture to adjust a video camera side to side, it won't be moved very often. I'm using a dovetail plate and a bearing in the main housing and moving the dovetail plate side to side with regular 1/4-20 threads. I don't know if that will work for linear motion but it doesn't need to move very often as I said. The plate is 2" deep. The question is how do I tap that deep, I can reach both sides but that wouldn't work because they wouldn't meet up and they wouldn't be long enough either. So how do a make a thread 2" deep? Or should I machine a recess hole 1/2" deep on both sides that the tap can fit in and then just basically tap the inner most meat of the plate?
Old 08-29-2009, 07:52 AM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
I think these might work for you, not cheap though
http://www.michigandrill.com/part/?p=72751
Old 08-29-2009, 08:04 AM
Andre' B is on a distinguished road
You can get pully taps that would work.
But the longer the mating threaded parts the closer the thread pitch of the male and female parts must be or things bind up.
So making a C'Bore from each side and just having a shorter threaded section would be a better design.
And nothing wrong with a deeper C'Bore from just one side.
And if it lets you use a more standard tool then all the better.
Old 08-29-2009, 09:17 AM
Originally Posted by Cartierusm View Post
......Or should I machine a recess hole 1/2" deep on both sides that the tap can fit in and then just basically tap the inner most meat of the plate?
Yes, that is certainly the easiest. Actually don't even bother going to the middle from both side, drill a clearance hole 1-1/2" from one side and then tap the remaining 1/2" from the other.
Better yet, in my opinion, get a thread insert of the type that has a standard thread on the OD and ID; I think 1/4-20 inside has 3/8-16 outside. Then you drill 5/16 all the way through, tap 3/8-16 for the length of the insert and screw it in. The insert will last much longer than the thread in aluminum and is much less likely to gall up.
Old 08-29-2009, 01:11 PM
Geof, that's what I was continplating last night while I slept, thanks for all the help everyone.
Old 08-29-2009, 02:12 PM
I wish I could do that, when I am asleep I am totally beyond any contemplation; perhaps you mean 'while I couldn't sleep', that is a condition with which I am very familiar.
Old 08-29-2009, 02:27 PM
Oh I don't sleep, I'm a real insomniac, but when I do sleep, usually during the day on the couch my brain has a way of working things out. Honestly that's probably why I can't sleep too much rolling around up there.
Don't know where you are but it's DAM HOT here today, San Francisco. BBQ Time.
Old 08-29-2009, 02:37 PM
....Don't know where you are but it's DAM HOT here today, San Francisco. BBQ Time.
Vancouver, just a few hours north and it is warmish here. I am taking a break from digging (by hand) a 200 feet long ditch across the back of my property. A good way to lose weight and get fit and it helps with the sleeping at night.
Old 08-29-2009, 03:51 PM
Dam, that's hard work. Why the trench? Plumbing Issue? You should have rented a back hoe, then added servors to control it, see there's always a new use for Mach3.
P.S. Geof, what type of threaded insert would you recommend from McMaster, http://www.mcmaster.com/#=3eivrk
Old 08-29-2009, 04:18 PM
This page the middle top: http://www.mcmaster.com/#threaded-inserts/=3ej0ms
Click and it will take you to more detail and there is a version with a nylon insert.
The ditch is a perimeter drain around my property. My wife and I live on an island in a river delta just south of Vancouver, Richmond actually where the Vancouver airport is. We have 1-1/2 acres surrounded on three sides by agricultural land so it is like living in the countryside but in winter we get a lot of standing water so I am putting in the drain to intercept surface flow from the neighboring properties. So far I have done just under 800 linear feet about 10 inches wide and 24 inches deep and have about 400 to go. I can't get in with a backhoe because of trees and gardens and buildings but anyway the exercise is good for me. I passed a major cardio test a couple of years ago with flying colors, cholesterol is good, good lipoproteins are high bad ones are low and five minutes on the treadmill hooked up with dozens of wires produced the correct kind of trace on the machine. I plan on keeping it that way for a few more years; I reckon I am doing pretty good at almost 66 and not on any heart drugs.
  #11   Ban this user!
Old 08-29-2009, 04:31 PM
Wow, that is good, better than me probably and I'm 36. Well good work. If I was around I'd help. I haven't been to Canada in a while.
tapping on a mini mill without rigid tapping??? mls Haas Mills 13 07-03-2009 06:43 PM
deep hole tapping problem ak_crabber General Metalwork Discussion 9 02-05-2009 05:44 PM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 12:49 AM
Real, real newbie!!! aggie_67 General CAM Discussion 11 02-04-2006 12:10 AM
tapping head vs hand/cordless tapping machine.... InspirationTool General Metal Working Machines 6 09-12-2005 08:10 PM
