Old 08-28-2009, 01:10 PM
zaebis is on a distinguished road
Feed and speed to machine HSS
I will have to mill off some part of HSS 1/2 x 1/2 square bar to make it fit for my needs by about 0.1-0.2" I plan on using 1" indexable facemill to do that. Any ballparks on reasonable feeds and sppeed and DOC for a small milling machine?
Old 08-28-2009, 02:07 PM
John Welden is on a distinguished road
Maybe around 800 RPM 5 to 10 ipm.
DOC, hard to say.
Old 08-28-2009, 02:11 PM
beege's Avatar
beege is on a distinguished road
Hardened? Surface Grinder!
Old 08-28-2009, 03:15 PM
no grinder. only mill is available.
Old 08-28-2009, 04:11 PM
beege's Avatar
Is this a lathe bit? If it is, it's going to be VERY difficult to cut on a mill.
Old 08-28-2009, 06:02 PM
Andre' B is on a distinguished road
Get a 3/8 bull nose end mill with 0.06 rads, YG X-Power are resonably good and inexpensive.
Spin at about 250 to 350 SFM.
Feed at about 0.002 IPF.
Run dry with maybe just a little air blast to get rid of the chips.
Use it like a face mill taking about 0.005 deep cuts.
Old 08-28-2009, 06:13 PM
Mcgyver is on a distinguished road
you're talking about an annealed piece of hss? otherwise, sorry, not a chance. ceramics will do some hardened carbon steels but you're not going to touch hardened hss with anything but abrasives
Old 08-28-2009, 06:19 PM
it is a lathe bit yet. It is used as a parting tool. I need it thinner. Is that not a chance on a mill?
Old 08-28-2009, 06:32 PM
zooloader's Avatar
zooloader is on a distinguished road
Hi , I had to mill a 6mm af hex broach tool, down to 3mm, a couple of weeks ago.
I used an Iscar multi-master 4 flute endmill with 1mm corner rad, grade IC908 (I think).
speed was 10m/min
feed was 0.02mm/tooth
DoC was 0.2mm
This worked beautiful, but took a long time! I was fortunate to have a nice rigid machine. The cutter still looked new when finished, and I went on to use it on some aluminium parts.
good luck
Old 08-29-2009, 05:48 PM
mbi mbi is offline
mbi is on a distinguished road
I plunge out broken HSS taps all the time. I use old reground endmills. They work remarkably well. Say .5 dia endmill 100 cs .002 ipm.
  #11   Ban this user!
Old 08-29-2009, 07:35 PM
I've milled it with carbide before.
And of course plunged taps out.
Need Help!- Help with Feed and Speed sa6200 General Jewelry Design Software 1 11-20-2008 11:48 PM
speed & feed kal_pesh Mastercam 1 07-21-2008 06:56 PM
speed and feed again fourperf Fadal 13 01-25-2007 03:53 AM
Feed & Speed Help kaleem1 General Metalwork Discussion 2 11-04-2004 07:21 AM
