Old 08-27-2009, 11:03 AM
lkenney is on a distinguished road
X axis torque alarm on Takisawa Lathe
Recently I have been getting an X axis torque alarm on my Takisawa EX-108. I think it is due to the fact I let the coolant run down and get sticky. Any ideas of what else would cause this? I really need to get my projects going.
Ardis
Old 08-27-2009, 01:38 PM
Smile
I went in with a scraper and cleaned under the rubber dams on X Axis then hit with a jet of water on the hose. This seemed to have worked at least for awhile. After gentle, slow manipulation of the X-axis, I was able to move around and am now working again.
Old 08-27-2009, 01:48 PM
Al_The_Man's Avatar
Give the ways a good coat of waylube oil. Vactra2 or?
Including the ballscrew, if you can see it.
Old 08-27-2009, 02:14 PM
Thank you, Al.
I had already gone in and looked at the ways and ballscrew a couple weeks ago and lubed them. At this point I am convinced that the problem lies in the fact I let the coolant get so low. (Not enough information when I started learning this machine regarding the coolant tank and how it worked.) When I started refilling the coolant tank yesterday, I put in almost the same amount of liquid that the tank holds. I am going to continue to run the machine and try to build up the "slickness" factor.
Takisawa CNC Lathe Communication Problem Masood Machine Problems, Solutions , Wireless DNC, serial port 2 06-26-2011 09:40 AM
Need Help!- Takisawa Lathe-saving program to computer? KCA324 Controller & Computer Solutions 0 07-06-2009 09:41 AM
Fanuc 0T-C Takisawa Lathe Dave1 Fanuc 17 06-13-2007 08:30 AM
Takisawa Tw-20, CNC lathe Masood Mini Lathe 11 09-22-2006 01:35 AM
Takisawa TC-2 Lathe kayleesdad Mazak, Mitsubishi, Mazatrol 11 05-10-2005 02:37 PM
