Old 08-25-2009, 07:53 AM
smooth72's Avatar
smooth72 is on a distinguished road
Wood router bits and Aluminum?
I was suprised what this person has done with what appears to be wood router bits and a hand drill mounted in a press. Maybee I wasted my money bying a mill machine.
http://www.diymobileaudio.com/forum/...-330-a-11.html
Here is a some pics from his build.
Old 08-25-2009, 12:36 PM
noisillator is on a distinguished road
Yes you did. I'll take it off your hands for $50.
Old 08-25-2009, 12:38 PM
ger21's Avatar
Aluminum is not that difficult to work with using standard woodworking tools. If you remove most of the waste material before routing, it routes fairly easily.
Old 08-25-2009, 04:14 PM
big_mak is on a distinguished road
I use wood router bits for corner rounding on my MC all the time. They are cheap and provide a good surface finish too over some HSS Corner rounding tools.
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 08-25-2009, 05:24 PM
smooth72's Avatar
Thanks for response. I am trying to absorb as much as possible. I have a Grizzly G0484 that I have not even put the plug on yet. I hope to build custom parts for my cars. I hope to gain allot from others knowledge.
Looking for a set of router bits for wood, plastic, foam and thin aluminum. bkboggy Wood Working Tooling 8 04-23-2009 11:06 PM
Advice on cutting bits for wood please? Ranscon WoodWorking 1 03-20-2009 09:21 PM
Cutting ali on wood router - low rpms breaks bits. Why? lsteele DIY-CNC Router Table Machines 21 01-06-2009 03:49 PM
Good source for wood bits Art Ransom WoodWorking 2 10-12-2006 11:00 PM
wood spade bits on aluminum??? lurch General Metalwork Discussion 4 01-16-2006 12:21 AM
