Old 08-21-2009, 02:28 AM
GMitchell is on a distinguished road
Milling 316 stainless steet, 1mm carbide tool$ keep snapping!
Hi, I'm a hobby machinist, general experience in aluminium and steel. I have to engrave some text into 316 stainless steel sheet with a 1mm carbide ball nose slot drill. They are very expensive, and I have snapped two, now I only have one left. What are your thoughts on speeds / feeds?
CNC'd RF45 Mill is limited to 1600 RPM, feedrates recommended by the manufacturer is 160mm per minute, but the slot drills snap off when I try and engrave at 50mm / minute, I wasn't brave enough to try 160mm / minute. what am I doing wrong? Can someone please help / give advice on speeds and feeds, because I am missing something here?
Thankyou, GM.
Old 08-21-2009, 02:45 AM
JimPAC's Avatar
JimPAC is on a distinguished road
SLOWDOWN
All weldable 300 SS is very gummy!
You spindle speed and rigidity are key!
Turn your spindle to 1000 rpm and slow your feed rate to less than 2. inches per minute.
Thin plate builds heat up fast so use plenty heavy cutting oil.
Just start slow and increase to best results!
SLOW DOWN
Old 08-21-2009, 06:47 AM
mxer is on a distinguished road
Also try taking light depths of cut.
Old 08-21-2009, 07:55 AM
Superman's Avatar
Superman is on a distinguished road
At 1600 RPM, your cutting speed is only 5 metres/min
This is quite slow, but you are stuck at this max RPM
The type of cutter you have may be the problem
Does it have to be a ballnose ?
can you use a D-bit cutter ? ( 3-6mm shank, 60° taper, 0.2mm point diameter) example
if $$$ allow, look for tapered cutters ( page 13, 915010-MEGA-T ) or something similar
You need to get support closer to the actual cutting action ( the taper helps )
For 1600 RPM
Z plunge rate approx 15mm/min
XY feed rate approx 30mm/min ( about 0.02 / rev or less )
We use D-bits, but run them at minimum 6000 RPM, Z plunge=70, XY feed=200 and depth of cut about 0.1-0.2 mm
Need help, milling 316 stainless steel, 1mm endmill. Keeps snapping. GMitchell General Material Machining Solutions 4 10-16-2011 10:41 PM
HSS vs Carbide for milling zaebis General Metal Working Machines 4 05-06-2009 02:45 AM
Need A Quote- Stainless Cnc milling sa6200 Employment Opportunity 5 02-04-2009 03:59 PM
Need Help!- 1/16 carbide endmill in 316 Stainless Steel cutting edge General Metalwork Discussion 5 09-28-2008 03:33 AM
Carbide tool life? ozzie34231 General Metalwork Discussion 11 11-01-2005 08:33 AM
