Old 08-12-2009, 05:32 PM
RBIEZE's Avatar
RBIEZE is on a distinguished road
Slitting saw tooth count ?
Hi .
I need to slit fins with a 2.00 O.D .032 thk slitter blade in Class 1 copper (99.9%cu) barstock .
The depth of cut will be .325
My question is should I run a fine 150 tooth or course 60 tooth cutter,and what Rpm/Fps I should try with each.
Thanks in advance.
Old 08-12-2009, 09:40 PM
I would go for the low tooth count because the chips tend to curl up and bind.
For speed something like 200 rpm, possibly if things go okay you can boost it.
For feed something like 2 IPM to start and if things go okay also move this up.
For lubricant try things like tap-magic; copper often tends to be gummy.
Old 08-12-2009, 10:29 PM
Hele63's Avatar
Hele63 is on a distinguished road
"now Cole tires are what win races"
Lower tooth than what you said, treat it like aluminum. We slit .012 thick all the time and the key to it is the holder. Support the blade as much as you can, we build all of our own holders for saw slitting. You want to make a holder that leaves about .100 - .150 of the blade exposed. and then taper down to your shaft size for your holder, almost looks like a pedestal, then just make the other side as a flat cup to hold the blade from slipping. PM me and i can send a pic of what i am talking about. We run 5" blades .032 thick at 1800 rpm and 23 ipm with oil do not use coolant use good way lube oil. if you PM me i can send the info for the oil as well.
Helmut Jr
Old 08-13-2009, 12:51 AM
Originally Posted by Hele63 View Post
...do not use coolant use good way lube oil. if you PM me i can send the info for the oil as well.
Helmut Jr
Way lube oil??????
I have never thought of that, thank you for a good suggestion.
Old 08-13-2009, 02:43 AM
RBIEZE's Avatar
Darn it ,I new I should have checked back...
I ordered some 110 tooth cutters this afternoon,Oh well.
I'll order some course tooth ones tomorrow.
Thanks for the speed/feed info geoff.
As far as the arbor goes I made a few today.
It was fun running turning operations on my mill,never had a chance to try that before only had to scrap the first piece
Require DXF/DWG for 35 tooth sprocket. Kiwi General CAD Discussion 4 06-16-2009 03:56 AM
Saburr-tooth burrs cncbcncb Wood Working Tooling 1 03-26-2009 08:13 AM
Where to buy 24/32 TPI straight-tooth set 131-1/2" Blade? + Q on wavy tooth sets mcm375 General Metal Working Machines 2 11-25-2008 10:28 PM
can I get a 13 tooth timing pulley unterhaus Bridgeport and Hardinge Mills 9 01-11-2006 11:11 AM
Cutting A Ten Tooth Spline On Vmc With 4th Axis rrrrrgh G-Code Programing 5 08-19-2005 05:33 PM
