Old 02-27-2005, 09:04 PM
cnc2k is on a distinguished road
Tapping aluminum question
First time working with metals, so here is the newbie question i have. Do i need to tap both peice of aluminum? (see picture)
Old 02-27-2005, 09:15 PM
HuFlungDung's Avatar
Moderator
No, you should drill a clearance hole in the first piece the bolt passes through, and tap the threads in the second part. Otherwise, your bolt will not be able to tighten one part against the other.
Question about machining aluminum mustbenu General Metal Working Machines 31 07-12-2005 08:41 PM
Extremely basic machining question. touser General Metalwork Discussion 9 06-19-2005 12:51 AM
Question about drilling Aluminum cross6 General Metalwork Discussion 11 11-15-2004 08:12 AM
Question on "billet aluminum" munkee General Metal Working Machines 1 09-28-2004 07:28 PM
Question about 2024 aluminum cnc2k General Metal Working Machines 7 09-08-2004 12:22 AM
