I need to thread an inner diameter as shown in the attached picture. The problem is that the start and end diameter is different (conic) and need to produce quite a lot of this part. is there another way to threads this?? i can use the lathe but i need to mass produce this part. is there a ways to speed up the process? perhaps taps that go at an angle ? Thanks |
| You haven't specified just what thread spec is required. Is this a standard NPT (pipe) thread, or a metric version of a pipe thread? Your best bet mill be to use a tap if you don't have a CNC machine or a manual machine with a taper attachment. Tell us what the thread specification is, what machine you have, and we can better help you. |
| The core size nearly looks like a 1/2" BSPT ( British Standard Pipe Taper ) But you still have to verify with the customer what he wants to fit into the part Code: "G: Series British Standard Pipe - Parallel ( Straight ) BSP or BSPF Also referred to as British Gas, British Pipe Parallel or Parallel Fastening thread. Various Symbols: BSP, BSPP, BSSPI, BSPF, BSPG, PS, R, G. Taps Marked " G Size I.S.O." ------------------------------------------ "Rc: Series British Standard Pipe - Taper- BSPT Also referred to as British Standard Taper Pipe or Pipe Taper, or Conical Thread. Taper is 3/4" taper per foot ( 1 in 16 on the diameter) Various Symbols: BSPT, BSPTr, PT, KR, Rc. Taps Marked " Rc Size I.S.O." |
| Newbie- machining left I D thread and O D knurling | chipcrazy | General Metalwork Discussion | 1 | 08-09-2009 05:36 PM |
| Angled head | Alirumba | EdgeCam | 1 | 06-28-2009 01:23 PM |
| angled bore ? | pit202 | Solidworks | 9 | 11-02-2008 08:11 PM |
| horn pin (angled pin) | spider | Moldmaking | 6 | 09-29-2007 08:37 AM |
| Angled Holes | john_mccarron | GibbsCAM | 2 | 05-31-2007 06:04 AM |
