  #25   Ban this user!
Old 08-07-2011, 01:11 PM
Karl_T's Avatar
Karl_T is on a distinguished road
Originally Posted by Spartan117 View Post
Ha, now it works like it should.
Your comments led me on the right track, thank you
Anyone here that uses his selfmade-fogbuster with only one pressure on tank and air?
We learned something. I average 1 email/ month on this. I'll pass on your knowledge.
My original was a copy of the henchforth patent with only one pressure. It worked by using a couple needle valves to restrict air flow. Then I tried two pressure regulators and got a HUGE improvment. That was 10 years ago now. I've not heard of any unit using one regulator working as well.
Karl
  #26   Ban this user!
Old 08-07-2011, 01:45 PM
Spartan117 is on a distinguished road
I must admit that i was VERY suprised how good it can be adjusted and how low the air-consumption is with the two regulators.
It can be used at 4psi air-pressure and it performs good anyway. The gauge of the compressor seemed to be nailed down^^
Maybe i can do some volume-tests in the tub, when my wife is away
Plz excuse my english, i'm german
  #27   Ban this user!
Old 10-24-2011, 09:49 AM
ddgman2001 is on a distinguished road
Originally Posted by Steve Seebold View Post
I have been using the Hench FogBuster since 2004. They are absolutely the best mister I have found to date.
I pressurize the tank with 40 PSI and I pressurize the nozzle with 6 to 10 PSI.
There is not much mist coming from the nozzle. Actually, if you can see the mist, that's too much.
I have the 1/2 gallon dual nozzle mister on all 3 of my machines, and that amount of coolant will last about 2 weeks when I work about 6 hours a day.
I'm trying to decide between one and two nozzles. It seems like a one nozzle setup could only cool two edges of a profile leaving the other two to gall up. Is that correct or am I missing something?
  #28   Ban this user!
Old 04-27-2012, 12:21 PM
Adam Donovan is on a distinguished road
I just finally finished my HFFB today and I must say Im totally blown away just how well it works. I was using WD40 air blasts and a vac before this(needed an extra arm) and all I could manage was about 1mm DOC in 6060 with an 8mm endmill. Now I can manage to get a 10mm DOC and the machine seems pretty happy.
Thanks to all of you for posting how you made your own.
mist collection for VM-1 rossrods HURCO 1 07-13-2009 12:22 AM
15k spindle air oil mist AndyB Fadal 7 03-14-2008 05:32 AM
Oil-Mist / Minimum Lubrication Ginger_Ninja54 General Metalwork Discussion 0 01-16-2008 04:56 PM
HVLP Spray Guns PaulH WoodWorking 7 01-17-2006 08:46 AM
Mist Collection automizer Safety Zone 6 01-03-2006 01:14 PM
