Sure, you can do that Dave,
Just adjust the compound rest to the desired angle and feed/cut with it and use the cross slide only to increase the cut for the next pass.
What angle that would be is your problem
Try a piece of dowel rod for testing the angle.
LinkBack URL
About LinkBacks
