depending on the job most of the time we have had good luck with special reamers with flute polish and od polishing at lower surface footage. we achieved a number 8 with 5 flute endmill on the sides of our part im sure you can also finish that hole with the same endmill and achieve the same result |
| i don't know much about surface finish numbers, but a quick google reveals disparity, some reference a mirror finish, others brush etc. is it .437 or is it .4375? makes difference if you're holding .0003....in that the first thing to try (if the later) is a sharp 7/16 reamer, run it slowly, feed it slowly and retract and slowly all with flood and you can get a good finish. If that finish isn't good enough, its not difficult, but can be time consuming, to put a mirror finish on via lapping. ream with an undersized reamer and start lapping with progressively finer compound. mirror will start coming out at 600 and really show its stuff at 1000. |
| If useage makes it cost effective, you might consider a burnishing tool or a burnishing reamer (Shefcut or Mapal etc.). www.cogsdill.com Dick Z
__________________ DZASTR Last edited by RICHARD ZASTROW; 08-08-2009 at 11:32 AM. Reason: add: |
| Zinc-Plated Finish vs plain finish for threaded rod? | Almaz | DIY-CNC Router Table Machines | 2 | 10-21-2008 03:39 PM |
| Finish on M2 | yoopertool | Mass finishing equipment/media/stratigies | 2 | 03-26-2008 07:43 AM |
| How to get this finish | dneisler | General Metal Working Machines | 3 | 10-11-2007 08:09 PM |
| Finish Cut How too ??? | Biggermens | BobCad-Cam | 6 | 04-30-2007 08:59 PM |
| Bad finish | fadalman | Fadal | 5 | 12-09-2006 02:00 PM |
