Hi, First of all I hope I got the right forum for my question. I have been reading about different ways of machining crankshafts for model engines. My own interests are in model steam engines and I have always made my crankshafts by machining all the crank pins and webs separately before silver soldering everything together, hopefully keeping everything straight and aligned. So I was wondering, is it possible to make a crankshaft from one piece of steel on a benchtop cnc mill with a 4th axis. As a more general question, is it possible to "turn" a shaft on a 4th axis mill with an end mill and how do the results compare to a lathe. Thanks. |
| I looked at this with my father in law's redwing hit and miss engine. For his shaft it was possible to offset a 4 jawed chuck to turn the ends leaving a billet in the middle. By then transferring it to a mill he could indicate in on each shaft end, vertically as well is X and Y and then center drill the billet to be mounter in between centers. Saw part of the billet away and the use a grooving tool to turn the center of the shaft, however it was a lot easier for me to make him one to demonstrate the process of making it in pieces and jigging it to hold it in position to solder it. I can't answer the 4th axis question with any authority as all my 4th axis work has been in index mode, however the drive/encoder of the 4th axis will determine how true of an arc you can produce on your shaft. Deflection on the scale of his engine would be a serious consideration as well.
__________________ Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself. Mark Twain |
| the short answer is no, because the bottom of endmils are not flat.....the bottom teeth slant a few degrees upward toward the centre so that they have clearance. So even if you could live with the finish, each pin would be a bit pregnant in the middle. Why not turn it in the lathe? there are many not-to-difficult ways to do this from solid. Here's the most complicated i've done, a three throw crank turned from solid (except the counter weights which were added afterward). anytime you turn a crank you have to make a fixture giving you the required centres for each pin - the secret is turn the pins first as as each is turned fill in the gap with a peice of very close fitting packing to maintain the rigidity of the shaft |
| Rotary Machining- Unwrapping of 3D model in Artcam resolved | Khalid | ArtCam Pro | 1 | 01-01-2010 06:50 AM |
| Need help with model engine head machining | Adaware | General Metalwork Discussion | 3 | 10-09-2008 03:56 PM |
| News - Cut3D - Low Cost 3D Model Machining | Tony Mac | Vectric | 18 | 04-26-2008 04:55 PM |
| Machining Large 3D Model- Slicing Options in different softwares | Khalid | General Metalwork Discussion | 11 | 02-05-2008 04:34 AM |
| MIS CNC Machining and tooling - General machining - Thermoform Molds | modernprecision | Employment Opportunity | 0 | 11-23-2007 11:05 PM |
